#1 |
Member#: 1465
Vehicle:2000 rs sedan brp |
i need a detail and correct techniques description for entering and exciting corner with fast speed?
i need detail on: when step on clutch, when to shift.. when to release clutch and break and/or gas... i had been drinving my std rs for like 6 months now and i am starting to think all my technique (most) is wrong.. please teach me how to drive it safe and fast... thx you every rs racer!!
#2 |
Member#: 2015
hmmm... maybe these links would help?
http://www.turnfast.com/ or http://www.drivingtechniques.co.uk/ |
#3 |
Guest
Member#:
Gerard, basically you don't shift or brake or anything mid-corner. Try to calculate the speed needed before the turn and downshifting or heel/toeing accordingly. For SOLO's and autox's it's mostly 2nd gear thru the corners. Your goal is to concentrate on turning and not shifting or anything else that might throw the balance of the car away.
#4 |
Member#: 2253
Vehicle:2000 2.5 RS Red |
The most important thing to remember is not to break or even let off the gas in a drift. A drift is when the car travels sideways thru a corner. Practice in a snowy or wet parking lot and you will see what I mean
| Thread Tools | |
| Display Modes | |
| What is the correct way to attach harnesses to a harness bar? | DiscoWagon | Newbies & FAQs | 2 | 06-18-2006 08:15 PM |
| What is the CORRECT way to get rid of wastegate flutter? | XWRATED | Factory 2.0L Turbo Powertrain | 5 | 05-25-2006 09:03 AM |
| What is the best way to make a cast in order to make a fiberglass mould? | BrysImpreza | Interior & Exterior Modification | 1 | 02-20-2006 10:21 AM |
| what is the correct way to do a dOnut? | byam52 | Brakes, Steering & Suspension | 15 | 01-04-2001 12:00 AM |
