Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 05-21-2004, 05:25 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Vendor Sales Rating: (95)
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Thumbs up Perrin Adjustable BOV now in stock
We have just received our first shipment of Perrin BOVs. You can individually adjust spring tension and flow rate with just your hands. All you have to do is twist the top!!! Comes with a WRX specific flange to bolt directly to your stock intercooler. On this flange you can adjust it to rotate 360 allowing the BOV to aim where ever you want it too.
Perrin Performance WRX/STI BOV - 224.99 Shipped!!!! LIMITED QUANTITIES!!!!!
We also currently have the following products available from Perrin Performance
Perrin WRX Panel Filters - 35.99 Shipped
Perrin Turbo Inlets(Blue only) - 224.99 Shipped
Perrin Oil Catch Cans(Blue, Black, and Red) - 116.99 Shipped
Perrin Intercooler Hose Kits(Blue, Black, and Red) - 134.99 Shipped
Perrin Radiator Hose Kits(Blue, Black, and Red) - 134.99 Shipped
Perrin Radiator Shroud - 59.99 Shipped
Perrin Positive Steering Response Systems - 170.99 Shipped!!!!
Perrin Short Ram Intakes(Blue, Black, and Red) - 170.99 Shipped
Perrin Crank Pulleys - 125.99 Shipped
Perrin WRX End links - 125.99 Shipped
Perrin Cat-Back Exhaust - 719.99 Shipped
Perrin Downpipe - 386.99 Shipped
Perrin WRX Rear Sway Bar - 184.49 Shipped
Perrin Manual Boost Controllers - 89.99 Shipped
Perrin Up-pipes NOW IN STOCK!!!!!! 224.99 SHIPPED
Perrin Fuel Rail Kit(Blue, Black, and Red) - 440.99 Shipped
We also sell the Perrin STI BIG MAF Kit and 720cc Modified STI Injectors.
The Perrin BIG MAF kit includes a Perrin Cone Filter, and a BIG MAF housing.
The Perrin 720cc Modified Injectors can be bought 2 ways. You can send your injectors in for Perrin to Modify them. Or you can buy Pre-modified Injectors.
These 2 parts when used together do not require additional engine management. ENGINE MANAGEMENT RECOMMENDED!!! This kit will increase the amount of fuel available to your engine and give you the ability to have more power.
Perrin Modified STI Fuel Injectors 740CC EXCHANGE $219.99 shipped
Perrin Modified STI Fuel Injectors 740CC NEW $639.99 shipped
Perrin STI Big MAF Short Ram Air Intake Kit $219.99 shipped
Ben
801.619.1779
www.rallysportdirect.com
[email protected]
RallySport Direct is offline
Old 05-21-2004, 07:52 PM   #2
chrisfranklin
Member#: 59737
2004 sti
crappy subaru white
is the bov 100% recirc?
chrisfranklin is offline
Old 05-21-2004, 09:29 PM   #3
RallySport Direct
Member#: 33174
We are Open Late!
chrisfranklin - yes, they are a full recirculating valve, or you are able to plum it to the atmosphere.
Old 05-22-2004, 11:59 AM   #4
Rallycarperson
Member Sales Rating: (29)
Member#: 53971
#35 SP Rally Car
MAP-RALLY.com
Default sound???
Im wonderin how the BOV sounds??? Any descriptions or sound clips??? Thanks.
Mark
Rallycarperson is offline
Old 05-25-2004, 06:56 PM   #5
RallySport Direct
Member#: 33174
We are Open Late!
__________________
Old 05-27-2004, 05:00 PM   #6
RallySport Direct
Member#: 33174
We are Open Late!
Bump
__________________
Old 06-01-2004, 06:20 PM   #7
RallySport Direct
Member#: 33174
We are Open Late!
bump
__________________
Old 06-04-2004, 03:40 PM   #8
myracle
Member#: 52636
'02 REX
It sounds wicked!! Get 1 dood
myracle is offline
Old 06-04-2004, 07:18 PM   #9
BDR
Member Sales Rating: (59)
Member#: 39445
2003 WRX/RA-Geared
07 Honda Fit VIP'd
do these come in Red?
BDR is offline
Old 06-12-2004, 12:16 AM   #10
2fastwrx3112
Member#: 62787
04 WRX
does this BOV cause idle or stal problems for the car in any way? I am looking for a BOV that can be recirc. or vent but wont cause problems to the car.
2fastwrx3112 is offline
Old 06-12-2004, 12:21 AM   #11
myracle
Member#: 52636
'02 REX
No.. it doesnt.. even better than SSQ
myracle is offline
Old 06-14-2004, 08:04 AM   #12
cat-les
Member#: 58847
02 wrx
Default how does it sound
what does it sound like at 100% reicrc is it still lounder than the stocker and what are the advantages over the stocker.
cat-les is offline
Old 06-14-2004, 03:39 PM   #13
RallySport Direct
Member#: 33174
We are Open Late!
Sorry about the late reply. Like some of you already know we have been closed this past week.
BDR- These do not come in red they are only available in the black shown
2fastwrx3112 - This BOV will not cause any problems in recirc mode. As long as you have it adjusted correctly it will work perfectly. It VTA(vent to atmosphere) for it will cause you to run rich in between shifts. And as long as you have it adjust well it will close 100% at idle giving you a normal idle with no stalling.
cat-les - It is slightly louder than stock in 100% recirc form. The main advantage over the stock valve is that this one is adjustable. You can adjust the flow rate and spring tension just by twisting the top.
We hope to have sound clips up soon.
Ben
801.619.1779
[email protected]
aim: rallysportdirect
Closed Thread
FS : Perrin Adjustable BOV STIckySTIfee Engine/Power/Exhaust 2 06-24-2010 09:46 PM
Perrin adjustable bov question Screwbal Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 09-23-2009 11:15 PM
NEW PERRIN Water/Meth Kit *In Stock Now* PERRIN Engine/Power/Exhaust 3 06-15-2009 12:00 AM
