Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 02-18-2000, 06:24 AM   #1
daytonians
Member#: 920
2000 2.5 RS Impreza
Sedona Red
Question Make hood scoop functional ???
I am picking up my new y2000 RS on tuesday. I was really supprised to find that the hood scoop is just for looks. Are there any kits avaiable to make it functional. I would really like to use a K&N filter also.
Thanks.
daytonians is offline
Old 02-18-2000, 06:43 AM   #2
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
The scoop is ment for an intercooler. Those who have made kits have found little to no improvement.
Revision is offline
Old 02-18-2000, 07:28 AM   #3
William WRX
Member#: 291
2013 Scion FR-S
Asphalt
Post
There are two kits out there that will make the scoop functional
- Minnam Stage II Turbo
- JC Sports Agressor Turbo kit
Sorry, I had to do that.
William
William WRX is offline
Old 02-18-2000, 08:26 AM   #4
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Post
Yeah the only way to make it functional it to buy a turbo
Bobalouy is offline
Old 02-18-2000, 08:35 AM   #5
Gambit
Member#: 102
Thumbs up
Or you can place tiny rockets and fire them at arrogant SUV drivers.
Gambit is offline
Old 02-18-2000, 07:13 PM   #6
Revision
Member#: 242
MY05 PSM GGA !STOCK
Post
Noooo!!! I don't want to start the mini gun on a swivel mount under the hood scoop thread again!!!
And no the laser didn't work out either. Vibration from the engine killed the flash tube...
Now a Trunk Monkey under the hood scoop... Naw thats just plain evil.
Revision is offline
Old 07-11-2000, 12:44 AM   #7
kaminari
Member#: 1781
2000 2.5RS
Blue Ridge Pearl
Post
Ok, I just did a search, and I found this topic, and I'm wondering is there any sort of splash/rain protection for the intercooler and hood scoop once it's opened up?
Or is water not a problem?
thanks
-kami
kaminari is offline
Old 07-11-2000, 05:44 AM   #8
HRE | giulio
Member#: 481
Post
not a mini gun... a fully auto paint ball gun
HRE | giulio is offline
Old 07-11-2000, 06:25 AM   #9
BoomerRS
Member#: 1271
98 RS
****in Rally Blue
Post
now im in on the paintball gun mod... what is the muzzle velocity of a paintball? would it be able to catch up with the car in front of me on the highway?
wow this is OT.
you would not want a splash guard for an intercooler.
try a search on this topic, there has been a lot of discussion on this.
a lot of people have removed the hood scoop backing with no problems... there is nothing in that area that cant get wet.
if you have a cone filter, you dont want water dripping on it obviously. you would have to experiment with that. some of us are using spacers on our vents to keep them somewhat open, but to direct the water. check the home depot hardware aisle for nylon or aluminum spacers or do a search in the classifieds, i think it was nick who was selling some. oh and rallispec makes them too.
i dunno if this helps... a search would be your best bet
BoomerRS is offline
Old 07-11-2000, 06:28 AM   #10
Revision
Member#: 242
MY05 PSM GGA !STOCK
Post
Usually between 100 and 200 fps.
If you have a MY00 you can make the hood scoop functional. Do a search for "Intake" under the username "8Complex" and you will find his DIY hood scoop, use only in good weather, watch out for cops, god this thing is loud.. intake.
[This message has been edited by Revision (edited July 11, 2000).]
Revision is offline
Old 07-11-2000, 08:36 AM   #11
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
In case you're as lazy as I usually am... http://8complex.mwic.org/intake/ will lead you to my intake. I'm working on a conceptual design for one I won't have to close during bad weather, as well.
8Complex is offline
Old 07-11-2000, 04:24 PM   #12
matt7184
Member#: 1797
2003 MazdaSpeed
Protege
Post
Actually at a high setting my pb guns can easily get 350fps, but if u change the spring 400+. Of course at fields they only let u use 300fps(outdoor,260indoor). How bout add a big spotlight in the scoop
matt7184 is offline
Old 07-11-2000, 04:40 PM   #13
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
not that muzzle velocity matters.... you will already be going as fast as the guy in front of you! If you're already going 80, so is the gun and paintballs.
North Ursalia is offline
Old 07-11-2000, 04:55 PM   #14
kaminari
Member#: 1781
2000 2.5RS
Blue Ridge Pearl
Post
that's right, paintballs do 300fps (about 204.54mph) at paintball fields, but you can crank it up higher depending on the marker you're using. (adjust springs, regulators and whatnot)
hmm... thanks!
kaminari is offline
Old 07-11-2000, 05:07 PM   #15
RallyGuy2k
Member#: 1146
Post
OK...back to the hood scoop thing....
YES.....technically you can make it functional just by taking it off...
With the cover on, the intake plennum box is quite HOT after a 10 minute drive....
However after taking the cover off and having the engine already hot and driving the same ten minutes, the intake plennum was MUCH cooler...
The scoop rams that air right on top of the box cooling it dramatically...therefore cooling the air inside. It might not be night and day, but at least now my hood scoop technically makes the car run better then not having it at all.
Tre' "Proud to have a functioning hood scoop" Ridings
RallyGuy2k is offline
Old 07-11-2000, 05:44 PM   #16
Deznuts05
Member#: 1410
2011 X5 Diesel
Space Gray
Post
hey 8complex... where did you find that conection from where the air fliter is to the engine???? and that hose that you said that you got from a friend what was that for again???? I don't see where it conects to
Deznuts05 is offline
Old 07-12-2000, 12:53 AM   #17
Keith
Member#: 191
2012 J train
Brown
Post
I have mine open now for like a month and I havent had a problem with water or nething. then again, my air filter is not close to the scoop.
have fun
Keith
Keith is offline
merging CAI and TMIC to make functional N/A hood scoop? sc00ter Normally Aspirated Powertrain 39 02-18-2009 11:34 PM
Anybody know of a mod to make your non functioning front scoop actually work? BleedingMascara Interior & Exterior Modification 13 07-14-2004 05:31 PM
Outback Legacy hood scoop functional? annointed Legacy Forum 11 01-23-2003 07:02 PM
Make RS Hood Scoop functional? snipes Normally Aspirated Powertrain 6 07-23-2001 02:10 AM
Is the hood scoop on the WRX functional? AKGC8 General Forum Archive 12 06-05-2000 03:40 PM
