05-21-2000, 01:28 AM | #1 |
Member#: 489
CE light... help
I have a apex N1 and resently got a custom midpipe with a highflow cat with O2 sensors to the front and aft of the cat.... CE light came on... resetted the ECU... now today... a day later my CE light came on a gain.... what should i do? could i have a bad O2 sensor?
05-21-2000, 03:15 AM | #2 |
Member#: 840
Vehicle:GC8! '00 2.5RS Silverthorne and mud |
I would have to say, and I could be wrong, You need more cat. The purpose of the rear sensor is not for engine management per say. It performs an emmisions function. The ECU will throw a CE if it doesn't see enough of a difference between the front and rear o2 sensor signals. I'd have to say that the rear sensor isn't malfunctioning, it's working perfectly.
Pete W. |
05-21-2000, 08:49 AM | #3 |
Guest
Member#:
Pete is correct. With just one high flow cat, the rear O2 doesn't see enough of a difference between the front and rear O2 output waveforms.
I had to install 2 high flow cats to get around the CE Cat light issue. Mark 99' RSt |
05-21-2000, 09:24 AM | #4 |
Guest
Member#:
OT, but how is the power with a high flow cat. i hear you loose too much on the lower end? thanks Impy
josh |
05-21-2000, 11:36 AM | #5 |
Member#: 137
Could one just keep the Cat the way it is and place a resistor on the O2 sensor. That way you'll read much lestt voltage. Just a thought on tricking the ECU that's all.
Mike |
05-21-2000, 11:51 AM | #6 |
Member#: 489
Not that much loss... i felt more loss when getting the cat back N1... and i dont have an intake so i dont feel much top end benefit... so i suggest doing intake first... its lot louder with teh new midpipe though... sounds different...
help: CE light help!! | DarkImpreza | Normally Aspirated with bolt-on Forced Induction Powertrain | 15 | 12-31-2001 07:49 AM |
CE light help | vinster02 | Bay Area Impreza Club Forum -- BAIC | 9 | 12-02-2001 04:42 AM |
CE Light Help?! | SubaTubaru | New England Impreza Club Forum -- NESIC | 4 | 07-31-2001 09:54 PM |
s-afc ,ce light help... | hondaconvert | Normally Aspirated Powertrain | 14 | 06-27-2001 09:26 PM |
another CE light. Help! | BongMan | Normally Aspirated Powertrain | 8 | 04-09-2001 01:29 PM |
