Old 05-23-2004, 12:42 AM   #1
Skully
Member#: 48990
98 Impreza RS
RBP
Default Tec-II maps
alright guys/gals i am wondering if anyone here has a 98 RS-T.
I have a minnam stage 2 turbo kit, custom fuel railes, RC550cc injectors. If anyone has a map that i could use as a guide or a identical setup they wouldnt mind sharing with me. I would really appreciate it. i checked about having a shop tune the car for me, and they want 175/hour to tune it.
Skully is offline   Reply With Quote
Old 05-23-2004, 12:54 AM   #2
Unsung Boxer
Member#: 37196
wow, for 175 an hour u could get a brain transplant.
save your money and get a wideband 02 sensor and EGT guage. Then tune it yourself. This way you can self-tune everytime you upgrade a part, and youll come out ahead in the long run.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 05-23-2004, 02:59 AM   #3
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
check www.forced4.com and you can see some 98 RS-T maps in there.
kevin
latinskllz is offline   Reply With Quote
Old 05-23-2004, 11:04 AM   #4
Skully
Member#: 48990
98 Impreza RS
RBP
he already sent me his map off his tec-II, but he is running high impedence injectors..and im running low. but i guess that would only throw the map off a little bit.
Old 05-23-2004, 10:11 PM   #5
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
Skully
I found some old TEC maps that I think are the old base maps that Shiv (vishnu tuning) used to have posted on his website. They'd be for a '99 and later SOHC engine, but if you want them, pm me your email address and I'll send them to you - assuming I can find them again.
Naturally, since I'm not even 100% sure what these were for, I don't guarentee anything - use completely at your own risk.
_Jeff
Portly is offline   Reply With Quote
Old 05-24-2004, 01:18 AM   #6
Skully
Member#: 48990
98 Impreza RS
RBP
wouldnt i still be able to use the maps? because the 99 has same compression as 98 9.7:1. It might make a difference that its DOHC, i dont know. cant hurt to find out.
Old 05-24-2004, 08:13 AM   #7
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Skully ~ I have a bunch of different map files from different models. Again, your best bet is to use them as a guide to see what others have had some success with. Over on Shiv's website, search for a thread which will walk you through initial tuning steps. The first and most important step is to determine a reason MIOT and offset.
If there's enough interest, I'll zip up all the map files that I have and host them for download.
SteveS is offline   Reply With Quote
Old 05-24-2004, 09:19 AM   #8
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
SteveS
If you're in the hosting mood, would you mind pm-ing me your email so I can fire these '99 maps your way too? That'll potentially save me a lot of emailing.
Thanks
_Jeff
Old 05-24-2004, 06:10 PM   #10
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Alright, various map files posted at http://www.forcefed4.com/25rs/tec-ii/maps/ .
Use these for tips and guidance.
Old 05-25-2004, 04:30 PM   #11
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Thanks Steve!
You rock!
crash is offline   Reply With Quote
Old 05-25-2004, 11:16 PM   #12
Skully
Member#: 48990
98 Impreza RS
RBP
woot, i got a map working awsome. i will post it once i get it completely refined.
Old 05-28-2004, 10:03 PM   #13
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
anyone got tec 3 maps?
subiekid is offline   Reply With Quote
Need Tec II Base Map cdigerlando Other Engine Management 0 07-02-2006 09:22 PM
O2 Sensors, TEC II, TEC III kaos200 Private 'For Sale' Classifieds 7 04-28-2004 09:12 PM
Where to find a TEC II NA map? seven881 Engine Management & Tuning 6 09-23-2002 05:47 PM
TEC II Update. Thoughts on NA TEC II Kit installation. Imprezer Technical Forum Archive 30 05-26-2000 08:37 PM
TEC-II / TEC-II Connection Port STi Sev Technical Forum Archive 10 05-25-2000 07:28 PM
