Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 08-07-2000, 09:32 AM   #1
IMPREZIV
Member#: 862
Question Just got whiteline sway bar, How to install?
OK, I just got my rear sway bar and I am way too lazy and busy to do a search. I was wondering if someone could post exact instructions on how to install (Im sure its easy. My only other question is how to figure out the settings. There are three holes at the end of the end of the bar and I was trying to figure out which one to put it on for the 18mm setting. Thanks
Pete
IMPREZIV is offline
Old 08-07-2000, 10:50 AM   #2
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
Post
4 bolts.
Take the bolts off where the bar mounts to the end links. Then take off the bolts that mount the bushing brackets.
Grease the new bushings and pop them onto your new bar. Then put the brackets onto the bushings. Route the new bar. Connect the bar to the endlinks loosely. Connect the bushing brackets back onto the frame. Tighten these. Tighten the bolts on the bar onto the endlinks.
Setting your bar:
ASCI drawing of bar:
o-o-o-----------------------------o-o-o
1-2-3-----------------------------3-2-1
Okay... the farthest holes out (1) is 18mm.
(2) is 20mm.
(3) is 22mm.
Hope this helps.
Pinochle is offline
Old 08-07-2000, 01:05 PM   #3
HomerJay
Member#: 1135
2005 WRX WAGON
Post
Careful with the grease that comes with the sway bar. It's contains lithium and is quite poisonous.
HomerJay is offline
Old 08-08-2000, 12:00 AM   #4
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Talking
wait for your exhaust to cool down! Damn that thing was hot fellas!8)
skidplatez is offline
Need advice on weather or not to install my Whiteline sway bar or wait. last lemming alive Brakes, Steering & Suspension 5 05-15-2010 09:13 AM
How to install Tribeca (25mm) front sway bar on an 96 impreza brighton - pictures Ninja007 Brakes, Steering & Suspension 3 11-15-2008 09:37 AM
Perrins adj Front Sway Bar... How to adjust? xcdhridr Brakes, Steering & Suspension 3 10-22-2005 03:42 PM
Audio n00b - got parts - no idea how to install - longish vennt Car Audio, Video & Security 19 10-04-2004 02:17 PM
Anyone got a link on how to install sparco seat slider? FryRice Newbies & FAQs 3 01-17-2004 03:20 PM
