Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 09-08-2000, 08:52 AM   #1
Puckaveli
Member#: 1518
00 2.5RS
Post Sulfer smell......nobody go in the garage for 25-35 minutes.
For the last two or three weeks. My car has had a strong sulfer smell after I shut it off. I know what clutch, antifreeze, and rubber smell like and it's not any of those. It's a MY00 with 11,000 miles and no performance mods so this is a problem. Can anybody shed some light on this for me?
Puckaveli is offline
Old 09-08-2000, 08:57 AM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
What brand or brands of gas do you purchase?
ColinL is offline
Old 09-08-2000, 09:00 AM   #3
8Complex
Member#: 922
04 FXT
Red
Post
How about brake smells? Just adding to the list.
I thought that sulfur smells usually came from your cat. and running too rich, but not sure if this could be your problem or not...
8Complex is offline
Old 09-08-2000, 09:04 AM   #4
FargoRS
Member#: 419
Cool
My 2001 Forester started smelling like sulfer at 4500 miles...the dealer scoped it and everything checks out. I read a service bulletin that says it could be the brand of gas, but I haven't changed since I bought the car and I ran the same gas in my 99 RS with no problems. I changed recently to a different brand and I still have the problem.
I drove in some flood water that was about one foot deep when Fargo ND was flooded bad a few months ago. I think I might have damaged the cat or O2 sensor from doing that. I'm going to insist they get replaced because the smell is more frequent and getting stinkier. Kind of embarrassing to have an egg fart smelling new car.
Mike
[This message has been edited by FargoRS (edited September 08, 2000).]
FargoRS is offline
Old 09-08-2000, 09:08 AM   #5
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
I had a horrible sulfur smell with my 325i whenever I used Unocal gasoline. Turns out BMW had actually issued a service bulletin stating that their cats were allergic to that particular brand.
So, I'd try switching brands if I were you!
RidinLow is offline
Old 09-08-2000, 09:28 AM   #6
Snoopy
Member#: 700
99 Impreza RS
Silverthorn Metallic
Post
You ran over a skunk.
Snoopy is offline
Old 09-08-2000, 11:50 AM   #7
Reflex-Arc
Lord of the Gif
Member#: 1703
Post
I've had a similar problem on occasion,but
I havent been able to figure it out. The RS hasent exploded yet, so I imagine its ok....
-RA
Reflex-Arc is offline
Old 09-08-2000, 02:11 PM   #8
Big Tee
Member#: 1802
1998 Impreza RS2.5
Post
Some years ago Chrysler had a tech bulletin out on this symptom and at that time Mobil was the culprit.
I sure think its fuel/cat related and though its annoying, probably not causing any damage.
Big Tee is offline
Old 09-08-2000, 04:07 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
munkis is offline
Old 09-08-2000, 04:52 PM   #10
Scooby do
Member#: 1217
2005 9-2X
Artic Silver
Post
My car does that stinky smell also, the dealer said it is because I don't let it warm up enough. I already had a fuel thing replaced, they are replacing the fuel control sensor this coming week. I run different gas alot so its hard to say if its a certain one.
Scooby do is offline
Old 09-08-2000, 05:07 PM   #11
TeamSUBARU
Guest
Member#:
Post
Try Beano?
"Say hello to my stinky little friend"
Old 09-09-2000, 12:26 AM   #12
Puckaveli
Member#: 1518
00 2.5RS
Post
i'm pretty sure it's not the brakes, but i think the gas might be a closer shot. i've been really bad about using the same brand lately because of all of the traveling i've been doing. i'm going to start using just shell and see if it stops. thank you all for your help. i'll keep you posted.
sorry about the no caps i broke both my flippin' shift keys.
Old 09-09-2000, 07:16 AM   #13
v6scoobie
Member#: 1563
Post
I have the same problem sometimes inside my car.usally I smell it in the cold weather with the heat on and windows locked and my family stuck in there with no way to get freash air.then all I hear is ohh dad put the window down.did you eat something dead.
v6scoobie is offline
Old 09-09-2000, 08:25 PM   #14
HondasRslow
Member#: 2332
Cool
well ive used chevron for a couple of years now and never had that problem, so give chevron a try, its good gas
-Alex
HondasRslow is offline
Old 09-09-2000, 08:58 PM   #15
dandbest
Member#: 1885
Post
Puckavelli,
I have a '99 RS with the very same problem. I called SOA and at first they said that it was the gas, but when I told them that I was using Exxon 93, they said "take it to the dealer" I also tried using Amoco 93,Shell 93, but nothing has helped. So now I have an appointment for Sept.21 so I'll let you know then. Until then, be happy that you arent the car behind you...
dandbest is offline
Old 09-10-2000, 02:42 AM   #16
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
Post
its could be your catalytic converters if you drive the car a short distance the carbon builds up on your cats. it smells because the water inside the cats are supposed to cycle and when you just turn the car off coming from down the street the water is going to stay in there. So its acts like a distillery in some way. thats how you get the sulfur smell. I had that probelm when i drove my eclipse but i havent experienced that problem with my impreza yet. I solved it by taking a couple laps before i stop. not the most convienient way to do it but it worked for me. Hey who knows i could be completely wrong if so why does it smell?
ac_gohan is offline
Old 09-11-2000, 06:43 AM   #17
brat
Member#: 1093
Smile
I have had the same problem for about 6 months now. My car is rather sluggish, and when I finally get it going, it seems like I through an anchor overboard and it quickly slows down. My friends tell me to shift at a higher RPM to "clean it out." I do and I get that awful sulfur smell. Could my cat be clogged?
Mara
brat is offline
Old 09-11-2000, 07:31 AM   #18
pfobrien
Member#: 950
'00 RS2.5 Coupe
Sedona Red Pearl
Exclamation
It could be the ECU.
There is a post on the general board about a Subaru recall coming on the ECU !~
pfobrien is offline
Old 09-11-2000, 09:01 AM   #19
rpone605
Member#: 1669
2004 WRX Sport Wagon
Post
Hey Puck sounds like your trunk monkey has gas!!!
rpone605 is offline
Old 09-11-2000, 11:02 AM   #20
Puckaveli
Member#: 1518
00 2.5RS
Post
He did eat a few sandwiches from Gyro Bob in the flats on Saturday.
Old 09-18-2000, 09:48 AM   #21
FargoRS
Member#: 419
Lightbulb
I'm curious what year your cars are that have the sulfer smell problem? My 99 didn't have this problem but it had the MAS on the intake. My 2001 Forester does not have a MAS and I wonder if the new configuration is keeping the engine from quickly compensating between rich and lean conditions which makes the CAT load up and stink. I also think most of us drive harder than the average Outback or Legacy owner, that's why we notice the smell. I may have a Forester, but I drive it has hard as my old RS.
Mike
FargoRS is offline
Old 09-18-2000, 11:24 AM   #22
AndyHidley
Member#: 1031
Post
Rotten Egg smell is a clogged cat. Like what was said above, running rich can clog them. Thus short trips with the choke on will be raeally rich. I have 14,000 miles on my 2000 and I buy the cheapest gas I can find, and I've never smelled that. But I drive 45 miles each way to work. Also a bad O2 sensor will cause that, because its telling the ECU to make the mixture richer, thus clogging the cat
AndyHidley is offline
"Don't nobody go in there for about 35....45 minutes..." Cole Off-Topic 37 07-02-2009 03:36 PM
I guess I'll go in the garage now... madmax718 Built Motor Discussion 0 06-21-2009 12:17 PM
Stuff In The Garage Sell!!!!!!!! Everything Must Go SL,UT_STI Engine/Power/Exhaust 1 11-23-2008 10:03 AM
If you smell something like bad popcorn in the garage... CameyDeuce Off-Topic 13 06-08-2007 02:37 PM
Going to the store for a few minutes, do I need to register the car? Nightwing Off-Topic 13 03-19-2007 09:49 AM
Message Board Statistics All times are GMT -4. The time now is 05:59 PM.
