Old 05-23-2004, 08:03 PM   #1
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
Default timing gear
hi everyone, i got a great deal on a 95 impreza but the crankshaft pulley nut wasn't tight and it ruined the pulley and the timing gear how do you remove the timing gear? thanks. damon
damonmlime is offline   Reply With Quote
Old 05-24-2004, 12:24 PM   #2
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
Default timing gear
nobody knows? surely someone has done it
Old 05-24-2004, 12:29 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I'm assuming you're talking about the crank timing gear right?
With the pulley off, t-belt removed the gear should just slide off the crankshaft. It is a pretty tight fit, but it just slides off the keyway.
You can find some pics of my timing belt change here
http://www.main.experiencetherave.co...ges/timingbelt
Legacy777 is offline   Reply With Quote
Old 05-24-2004, 05:07 PM   #4
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
Smile timing gear
thanks legacy777, i'll try that tommorow hope it works. thanks. damon
WTB 02 wrx left exhaust cam gear and crank timing gear 316 honda tech Private 'Wanted' Classifieds 0 03-30-2010 08:45 AM
EJ257 Bits: Oil Feed Lines, Timing Covers, STI Valve Covers, Timing Gears,Oil Pan etc DSM_Outback Engine/Power/Exhaust 16 10-20-2009 01:01 PM
WTB: Crank Timing Gear/Crank position Gear Letze Private 'Wanted' Classifieds 10 08-14-2009 01:19 PM
DOHC Phase I timing gears austenf740 Private 'Wanted' Classifieds 5 03-23-2007 03:47 PM
timing gears takumi Normally Aspirated Powertrain 0 06-19-2001 02:47 AM
