Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Closed Thread
Old 05-23-2004, 09:54 PM   #1
rigmiester
Member#: 59399
2004 wrx
Talking I have the colors you are looking for...
Yo man look under the steering column and find the blue plug and the blue tube with wires in it... Cut it open to see all the wires...Black/blue stripe=accessory wire, black=ignition, black/yellow stripe=starter, black/white stripe=constant 12V...When hooking up the TT to the aftermarket alarm you need to unplug the Accessory wire from TT and tape it (not going to use it). Cut the ignition wire that is going from the alarm into the ignition harness (black wire) then hook up that ignition wire from the alarm to the Accessory wire in the ignition harness (Black/Blue wire)...All set...2004 WRX...I had to sit there with a volt meter and see which wire had power and which didnt. Originally I hooked up my Crime Guard wrong so now I had to redoit...Now its deffinately right...Now you cannot activate alarm while the car is on, but once you take the key out, you can...This might sound confusing, but if you need more help let me know the wire colors from your alarm and the wires from the TT and I will draw a diagram for you...I'm glad to help...rigmiester@yahoo.com
rigmiester is offline
Old 05-24-2004, 01:00 PM   #2
bleuquila
Member#: 31922
03 wrx wagon
fastAr than sound
mix up your with ?
bleuquila is offline
Old 05-24-2004, 06:51 PM   #3
rigmiester
Member#: 59399
2004 wrx
Default yes I did, once again
My fault, sorry
Closed Thread
Hey! If any of you are looking for any last-minute gift ideas for me... TarmacRally Off-Topic 64 12-25-2009 01:47 PM
Hey. If any of you are looking for any last-minute gift ideas for me, I have one. Mayor McCheese Off-Topic 29 12-25-2008 12:52 AM
If you are looking for WINTER tires you may want to check this out eSToI Loco Tire & Wheel 13 01-07-2006 05:36 AM
The answer so many of you are looking for. The TRUTH. (why did I run slow) Davenow Proven Power Bragging 82 11-21-2004 01:41 PM
If you are looking for JDM parts look inside midnightblackwrx Mid West Subaru Owners Club Forum -- MWSOC 5 02-10-2004 12:14 AM
