Old 05-23-2004, 10:29 PM   #1
65 mustang
Member#: 40682
Default Wastegate question
Im really new to turbo cars in gerneral. Please dont flame. If im turboing a 2.5 rs with a td04. Where should i run the vacume line from the wastegate. Im assuming somewhere in the intake manifold that will get vacume. Also is it possible to run extremly low boost on my car. Around 4 psi or even no boost at all. I want to run low boost because i dont have fuel management yet. Thanks.
65 mustang is offline   Reply With Quote
Old 05-24-2004, 12:14 AM   #2
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
You will tap into the pressure side of the turbo outlet. Use a brass elbow that has a "screw in" fitting on one side and a barbed fitting on the other.. this is the easiest place to put it. I will see if I can find a picture for you..
http://www.forcedairtech.com/stage3.html
this is a horrible picture, but if you look at the turbo you can see where the fitting is placed, just inferior to the blue silicone fitting on the pipe leading to the intercooler. hope that helps.
Pi7467mp is offline   Reply With Quote
Old 05-24-2004, 12:16 AM   #3
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
if you don't want boost don't hook up the vacuum to the wastegate.. this will leave the wastegate valve open all the time, not allowing any boost to be produced..
Old 05-24-2004, 01:31 AM   #4
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
That's exactly what you DON'T want to do! If there is no boost source to open the wastegate, the turbo will boost up to its limits (ask me how I know!). There must be a source of boost connected to the port on wastegate actuator.
That said, the actuator on the td04 from a WRX will run at about 8lbs. I'm not sure if there are lower boost options out there... If you want 0 boost, disconnect the actuator from the flapper so that the flapper can open freely...
-Charlie
phattyduck is offline   Reply With Quote
Old 05-24-2004, 02:33 AM   #5
65 mustang
Member#: 40682
-Charlie
Yep i agree that the turbo will run unlimited boost with the wastegate not hooked up. Thanks for the responces. I figured out how it worked about 5 min after posting this. I think im going to adjust the wastegate so that it never closes (so i get just a little boost. Or we will disconnect it.
Old 05-24-2004, 03:24 AM   #6
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
NeaD is offline   Reply With Quote
Old 05-24-2004, 03:26 AM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
sorry man but its deadly info like that which pisses me off about the board
Old 05-24-2004, 03:50 AM   #8
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
People can make mistakes right? We aren't all perfect, lesson learned. I just hope he didn't read the post and immediately go do it
benjaminetanyahoo is offline   Reply With Quote
Old 05-24-2004, 03:51 AM   #9
NeaD
Member#: 43371
Hydra User, Blue
he knows, don't worry about that.
Old 05-24-2004, 10:33 AM   #10
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
um
its just that people were giving me **** about me saying i was sick of wrong info
and then that guy, who was IN THAT CROWD, goes and says something like that
Downpipe/Wastegate Question Egan Factory 2.0L Turbo Powertrain 7 01-16-2003 03:27 PM
WRX Turbo Internal Wastegate Question seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 12 08-29-2002 12:56 AM
wastegate question racerwad Normally Aspirated with bolt-on Forced Induction Powertrain 4 04-18-2002 10:47 PM
Turbo and Wastegate question yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 5 10-28-2001 01:28 AM
Blow off valve and wastegate question 2.5GT Factory 2.0L Turbo Powertrain 5 06-06-2001 04:58 AM
Message Board Statistics All times are GMT -4. The time now is 01:15 PM.
