Old 05-23-2004, 11:44 PM   #1
AUTOwrXER
Member#: 5817
2005 STi
Talking I'm going to listen to lots of Mustang/Camaro drivers cry...
as I'm planning to campaign a 2005 STi in ESP this year. Or more correctly, I'll be campaigning it until they boot it into BSP. I'm going to invest in a set of Hoosier radial wets so I can mop up their tears
Oh, the list of mods is growing every minute. I'm so glad I can use the UTEC now without it being an issue. Now I get to tune with C16 and water injection as well
I'm going to miss the STX crew. You guys are a great crowd. I hope we run on the same day at nationals this year. If I drive as well as I hope, you may find me in the protest shed. I'm sure the big iron won't give up easily, but everything on the car will be to the letter of the law.
Joel Fehrman
AUTOwrXER is offline   Reply With Quote
Old 05-24-2004, 12:44 AM   #2
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Default Re: I'm going to listen to lots of Mustang/Camaro drivers cry...
Joel,
What changed with the UTEC to make it SP-legal?
-Steve
MNbiker is offline   Reply With Quote
Old 05-24-2004, 12:56 AM   #3
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Definitely curious to know how the UTEC is legal in ESP?.
DrBiggly is offline   Reply With Quote
Old 05-24-2004, 07:43 AM   #4
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
bump for curiosity
trojan9x is offline   Reply With Quote
Old 05-24-2004, 08:09 AM   #5
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
STX and ESP are running the same days at Nationals (Tuesday/Wednesday). It should be interesting to watch. There are at least one or two other fast STX drivers from last year who jumped ship to ESP. Good luck, we'll be rooting for you!
TheWRX is offline   Reply With Quote
Old 05-24-2004, 08:20 AM   #6
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
adios!
i noticed you're headed to the Peru Tour but not Toledo. are you gonna run the STi there? if so, need a codriver???
Orion is offline   Reply With Quote
Old 05-24-2004, 08:22 AM   #7
KC
Member#: 442
13 Crosstrek XV
00 S2000
Wow, have fun Joel! You have the new '05 too... with the new front limited slip and other 'improvements'. A great example of why not to buy a 1st year car.
I think the '05 is going to be mighty quick.
Yeah, nationals is going to be fun. I'm starting my rain dance now.
And I'm also curious how the UTEC is now legal.
--kC
KC is offline   Reply With Quote
Old 05-24-2004, 09:31 AM   #8
del105
Member#: 43010
1974 2002tii
After looking at the rules, I guess Joel "could" use utec in ESP. ST class is very specific about about engine management while SP just says:
"Alternate computer control modules may be used whenever an equivalent change to the conventional system is allowed. For example, alternate computer module control of ignition settings or fuel injection is allowed. Direct turbocharger boost control by alternate computer control is not, since there is no equivalent mechanical allowance."
So I guess if you ran the boost wire from the boost solenoid to the stock ecu and back then the Utec would be legal in SP.
Andrew
del105 is offline   Reply With Quote
Old 05-24-2004, 10:00 PM   #9
AUTOwrXER
Member#: 5817
2005 STi
That's exactly right, Andrew. I'll be using the UTEC the same way I was in STX before we learned that it took direct control of timing (and now timing as well). Engine management is open so long as I don't touch boost controls. The wastegate wire bypassing the UTEC directly to the ECU meets that requirement.
Old 05-24-2004, 10:03 PM   #10
AUTOwrXER
Member#: 5817
2005 STi
Originally posted by Orion
adios!
I'm not sure about my plans just yet. The ESP development will start when I'm convinced it can win in BSP. Otherwise I need to stick to AS or STU. Right now I think the car can be on pace in BSP once prepped to the limit, by a) I'm not exactly sure that staement is true and b) I'm not sure I want to spend the $20k to go all the way to the limit...
My co-driver is pretty pumped, so I expect him to make the trip to Peru. Thanks for the offer though
Old 05-24-2004, 10:06 PM   #11
AUTOwrXER
Member#: 5817
2005 STi
Any guesses what I can get the weight down to in SP? I think I can make upwards of 320HP at the wheels in SP trim, but the weight will be important if BSP is in the future (which I fully expect, btw).
Old 05-24-2004, 10:40 PM   #12
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
I would guess 2900-3000. Dont think you can get much lower unless there are some weight dropping mods I cant think of.
afpdl is offline   Reply With Quote
Old 05-24-2004, 10:53 PM   #13
AUTOwrXER
Member#: 5817
2005 STi
I should have the car on the scales Wednesday night for baseline corner weights. I guess I'll know better after that. I'm not sure 2900 is attainable.
FWIW, the car should weigh less in ESP than if it gets moved to BSP because of update/backdate with the WRX. For example, you could backdate to the WRX wing or lack thereof in ESP, but you would be required to run the wing in BSP.
If the car is moved to BSP, I hope someone does a good WRX in ESP and beats the complainers still
Old 05-24-2004, 11:03 PM   #14
jmott
Member#: 6713
2007 Prius
brown
I will codrive for you at nationals and get the win
jmott is offline   Reply With Quote
Old 05-24-2004, 11:05 PM   #15
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
You cant update back date with a wrx in ESP right now they are on different lines to prevent you from doing it.
I can tell you my car with a lightweight battery, 1/4 tanks of gas, sparco roadster seat with slider and mount, hks downpipe, no catback, jic coilovers, sdrs with 245 victos on it weighed just over 3100.
You can still pull the a/c, lightweight passenger seat, lighter wheels, steering wheel, get rid of the seat belts, heatsheilds, and a few other things.
And the 05s are supposably a few lbs lighter due to some body panels, and a few other peices.
Old 05-24-2004, 11:08 PM   #16
del105
Member#: 43010
1974 2002tii
Joel, you can replace spoiler even in BSP the rule is long so I'm not going to type it out but I'm pretty positive you're allowed.
Unless the Wing is considered factory trim? but I think the 05 STI is offered with wing delete option so if thats the case it wouldn't matter.
Old 05-24-2004, 11:11 PM   #17
jmott
Member#: 6713
2007 Prius
brown
lightweight flywheel and clutch
drop more of your exauhst
lightweight rotors
find a jockey to drive for u
Old 05-24-2004, 11:16 PM   #18
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
There is no more exhaust to drop Crank pulley is another couple of lbs, headers would save some weight too. If you can add wings in sp I would imagine you could remove wings but I dont have a rule book to look through.
Oh I also had a radio/amp in the car so thats another few lbs.
Old 05-24-2004, 11:21 PM   #19
jmott
Member#: 6713
2007 Prius
brown
when I drove it the muffler was still hanging from the car =)
Old 05-24-2004, 11:22 PM   #20
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
No when you drove the muffler was fully attached. When I weighed it at the national tour the muffler was off the car.
Old 05-24-2004, 11:23 PM   #21
AUTOwrXER
Member#: 5817
2005 STi
3100 with you out of the car, correct?
Old 05-24-2004, 11:26 PM   #22
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Yes out of the car. The car would have to be under 2900 to weigh in at 3100 with me in the car
Old 05-24-2004, 11:28 PM   #23
AUTOwrXER
Member#: 5817
2005 STi
I know. I know.
Damn. I heard this dirty rumor about the car being significantly lighter than listed. It's not true, but a big part of me wanted to believe it. Kind of like how I want to believe the STi will stay in ESP
Old 05-24-2004, 11:30 PM   #24
AUTOwrXER
Member#: 5817
2005 STi
I didn't see anything when I read the rulebook a few days ago, but I was dozing off. Is the car really available without the wing? I would have done that in a heartbeat...
Old 05-24-2004, 11:40 PM   #25
Midnight_Gold
Member#: 37599
Comm ando Brigade..
Bring it isshes!
This is gonna be fun!
- Miranda
Midnight_Gold is offline   Reply With Quote
This is going to get a lot of you bent out of shape. RE: Brake upgrades Davenow Newbies & FAQs 688 05-02-2016 01:35 PM
I'm interested in listening to NIN. What would be a good album to start with? El Camino Off-Topic 90 03-06-2009 10:13 PM
this is going to break a lot of hearts brentyloke General Community 5 10-25-2008 12:36 AM
So... I'm sitting here listening to one of the greatest things wyn525i Off-Topic 10 05-27-2005 11:08 PM
lots of nice WRX drivers on the way to work this morning! RidinLow Tri-State Area Forum 1 06-25-2002 12:35 PM
