Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 07-10-2000, 11:55 AM   #1
Narso
Member#: 1442
1999 2.5 RS
Question UR Pulley Questions
I just got my pulley from Teague's. Now I need to know the right tension for the belts before I go pulling the car apart. Any one know what that is supposed to be and how I can measure it? Also, when I reset my ECU, am I supposed to lose my radio station presets? I have lost my trip odo readings, but that's it. Does this mean I'm not letting the system discharge long enough?
TIA Dan Z.
Narso is offline
Old 07-10-2000, 01:38 PM   #2
Travis R
Member#: 153
'07 Mazda CX-7, '91
BMW 535i & '06 Ninja 650R
Lightbulb
Just so you know, you shouldn't have to reset your computer when you install the underdrive pulley (assuming that is the only mod you've done, of course). You haven't changed the amount of air or fuel going into the engine, only decreased it's parasitic loss.
Travis R is offline
Old 07-11-2000, 12:24 AM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Check the owner's manual, it tells you how to check belt tension. Keep in mind that you'll have to adjust again later as the belts break in.
Yes, since you've cut electrical power to the car, it will forget your radio presets as well as the trip odo.
RidinLow is offline
UR Pulley questions, Need help quick ATX25RS Transmission (AT/MT) & Driveline 7 10-19-2001 03:30 AM
F/S: GAB strut bar + UR Pulley + FPR adrian03 Bay Area Impreza Club Forum -- BAIC 5 03-13-2001 12:33 AM
where can i buy gates belts for UR pulley in the Bay? BongMan Bay Area Impreza Club Forum -- BAIC 6 12-24-2000 12:54 AM
UR Pulley questions concerning torque specs Scoob_13 Normally Aspirated Powertrain 6 10-24-2000 11:51 AM
Part #'s for stock pulley belts...removing UR pulley SFsube Technical Forum Archive 4 08-26-2000 09:46 PM
