Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 09-17-2000, 04:58 AM   #1
codemunky
Member#: 1804
Post How can you tell if your diff is not working?
I don't know if it's me, but, I've noticed more skids after the dealer has replaced it. I've noticed it when powering turns. I'm not sure if it's a faulty diff or not. How can you tell if your diff doesn't work right? Or can you adjust sensitivity?
codemunky is offline
Old 09-17-2000, 04:33 PM   #2
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Post
It's not adjustable..at least not in this country... as for effectiveness...jack the car up in the center....spin one tire by hand...if the other tire rotates the same direction...you're all set...if not...something's up. The only thing this doesn;t tell you is at what point the limited slip begins to slip.
Hope this helps,
Fitz
Fitz is offline
Old 09-17-2000, 05:14 PM   #3
Thug
Choke Artist
Member#: 603
Post
which diff are you talking about?
Thug is offline
Old 09-17-2000, 05:22 PM   #4
scooby5
Member#: 1998
1999 Impreza STi v5
Silver Mica
Post
If I spin one of my front wheel, the other side rotates the opposite way.
Which diff were you talking about?
scooby5 is offline
Old 09-17-2000, 05:28 PM   #5
Tim K.
Member#: 214
2014 Massey Ferguson
Red
Post
I'm assuming they are talking about the rear diff, the one that is LSD on a 2000 and up. The front is an open diff. That is why on the front one tire spins forward and the other back.
Tim K. is offline
Old 09-17-2000, 09:53 PM   #6
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Post
Sorry for being vague. I assumed they were asking about the rear limited slips although doing this on the front end will only tell you the obvious; that our front limited slip is non-existent. As for the rear, both wheels should spin in the same direction on a car that is equipped with a limited slip. Keep in mind that thid does not tell you at what point your l.s. lets go... just that with no bias in rotational friction values that it's still working fine.
Fitz
Fitz is offline
How can you tell if your turbo has a clipped wheel? SolidSnake General Community 0 02-25-2006 02:11 PM
So how can you tell if your post was deleted? jonny_boy Off-Topic 8 08-07-2003 09:42 AM
How can you tell if your clutch is slipping? SoLo OnE Transmission (AT/MT) & Driveline 7 06-12-2002 02:05 AM
how can you tell if your differential was damaged due to towing? yuzo Service & Maintenance 5 12-30-2001 02:53 AM
How can you tell if your boost gauge is accurate? megatron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-01-2001 07:24 PM
