Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-18-2000, 07:39 AM   #1
TMR Impreza
Member#: 168
2011 M3 and STI
white
Question Has anyone removed the stock Knock sensor??
Just wondering if anyone has??
www.wonderlan.com/~hksupra
TMR Impreza is offline
Old 05-18-2000, 10:04 AM   #2
cvalle-sd
Member#: 420
2001 Cr-V
Question
You know, considering we're using the ITC and the AFC - why not? Are you thinking about another sensor, or going without (a little sketchy, maybe) I'm wondering if the knock sensor triggers because of my advanced timing. I'd like to have some indication of knock without the ECU necessarily getting in on the action. - there's gotta be more power in there.
cvalle-sd is offline
Old 05-18-2000, 11:24 AM   #3
MPREZYA
SCIC
Member#: 85
Post
Chris I can see you right now with a modified stethascope attached to the cylinder head run to the interior of the car driving around listening for knock while crusing. (I know that this could work but why do it?) TMR I need to talk to you as I want to get some parts from you! E-mail us2only@msn.com or call me as I want to try and get them this weekend if possible.
Rich
MPREZYA is offline
Old 05-18-2000, 02:50 PM   #4
SKiDaZZLe
Member#: 19
Post
removing knock sensor causes limp-home mode. if you find away around this, then you're set.
michael
SKiDaZZLe is offline
Old 05-18-2000, 03:40 PM   #5
mjos
Guest
Member#:
Post
Although I wouldn't recommend it you could just remove the Knock Sensor, plug the hole and then zip tie it(still plugged in) to a wiring harness. I would try the rubber isolator first if I were going to remove mine..which I'm not.
Mark
99' RSt
Old 05-18-2000, 03:53 PM   #6
shiv
Member#: 607
Post
Mark,
I don't think that will work. I beleive the stock ECU requires some type of active signal from the knock sensor to keep it out of limp home. I could be wrong though...
shiv
shiv is offline
Old 05-18-2000, 04:54 PM   #7
Trey
Member#: 670
Post
You might also try measuring the resistance across the sensor and just unplug the harness from the sensor and plug in the proper resistor to the harness. I don't know the resistance off the top of my head but it shouldn't take more than a few seconds to find out. The computer will think it's there and I don't think it would throw any codes but I haven't tried it yet.
We use to do that all the time with RX-7s after installing a J&S. The stock knock sensor sometimes reacts to things that aren't really knock. I'd put more faith in the J&S anyday.
And hey, if you have J&S, you could put your sensor right in the stock location. Maybe Subaru found that to be the "optimal" knock sensing location...who knows!
Have fun,
Trey
CobbTuning.com
Trey is offline
Old 05-19-2000, 06:52 PM   #8
WhiteCoupe
Member#: 1510
Question
Remove the knock sensor from it's original place.
Try to connect a wire directly from the negative pole of your baterry to the knock sensor.
It will works......
Martin
WhiteCoupe is offline
Tapping the stock knock sensor, will this work? Ziggyrama Commercial ECU Reflashes 9 06-12-2007 07:02 PM
can the stock knock sensor be used for knocklink? blackie Engine Management & Tuning 3 08-24-2004 02:22 PM
Reading the Stock Knock Sensor subachad Normally Aspirated with bolt-on Forced Induction Powertrain 5 01-22-2004 02:12 AM
Essay on the stock knock sensor, DeltaDash, and engine management ... wayoutwest Factory 2.0L Turbo Powertrain 2 01-24-2003 12:40 PM
Anyone try this with the stock knock sensor? 8Complex Normally Aspirated Powertrain 3 10-20-2000 05:49 AM
Message Board Statistics All times are GMT -4. The time now is 07:08 PM.
