05-19-2000, 02:01 PM | #1 |
Member#: 262
Vehicle:2000 2.5 RS BRP |
belt tension?
I am going to be installing the underdrive pulley this weekend and was wondering, how do I tell if the belt is at the correct tension?
I have seen the prior threads about about some people having problems with the belts getting too loose after the install and am hoping to avoid this.
05-19-2000, 02:07 PM | #2 |
Member#: 52
The best thing to do is to check the tension on the stock belts before you loosen them and just duplicate that tension. Basically you can move the stock belts about 1/4 - 1/3" if you push in themiddle of their longest run. The thing to watch out for when you install the new belts is to make sure that there is enough adjustment left once the belts are at the proper tension so that you will be able to tighten them up again after the do teir initial stretch after about 100 miles.
FS: 2.5L dual cam timing belt, tensioner & tensioner adjuster $150 | fornetti14 | Legacy Specific Parts | 0 | 06-20-2009 08:45 PM |
Broke the ac belt tensioner, but ac belt is still tight. Am I safe? | garface | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 01-12-2009 04:18 PM |
Advice on timing belt parts, i.e. belt tensioners on EJ22 | SubarNoober | Normally Aspirated Powertrain | 1 | 02-21-2008 05:10 PM |
Where is belt tensioner for the AC belt | Stover954rr | Service & Maintenance | 3 | 06-17-2006 02:15 PM |
Pay shop or DIY Timing Belt Tensioner and inner drive belt | erikkellison | Service & Maintenance | 23 | 02-26-2005 02:28 AM |
