Old 05-24-2004, 03:15 PM   #1
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
Default Turbo too close to power steering lines
Ok.. the turbo is very close to the power steering lines.... I ziptied them so that know they are about half an inch apart..... also I wrapped the lines in aluminum foil to make it sort of a heat shield
Also, the turbine is touching the chasis.. well... barely, but it does touch when I crank the engine.... I was told to put a piece of silicone in between the turbo and the chasis... any other ideas?
maxiav is offline   Reply With Quote
Old 05-24-2004, 03:38 PM   #2
4wheelmotion
Member#: 2044
1999 2.5 rs-T
rally blue/ '96 jetta vr6
i haven't had problems with my lines. i just left them. can't help you with turbine? chasis?
4wheelmotion is offline   Reply With Quote
Old 05-24-2004, 03:42 PM   #3
maxiav
Member#: 40413
2001 BRP RS-T EJ257
The turbine = turbo....
It touches the frame....
Old 05-24-2004, 05:14 PM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
FrAmE?!
show pics
Old 05-24-2004, 07:49 PM   #5
Lo0mis
Member#: 12469
2000 2.5 RS
BRP
Silicone would probably melt if your talking about the turbine half of the turbo. The compressor half would probably be OK. As stated, pics would help.
Lo0mis is offline   Reply With Quote
Old 05-24-2004, 09:15 PM   #6
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Max is referring to the compressor. Its not as bad as it sounds. Just lightly hits the chassis while cranking and the power steering lines run a little too close to the compressor. Other then that its not touching. Its an old Minnam kit and his car is a 2001 so fitment was not perfect. Some small fab work to the up-pipe can fix this problem.
WRC 555 is offline   Reply With Quote
Old 05-25-2004, 09:28 AM   #7
maxiav
Member#: 40413
2001 BRP RS-T EJ257
My bad... I meant the compressor ...
Guess I'll get some silicone to wrap the power steering lines...
Thanks!
IC spray bottle - too close to turbo? phoenix_wrx Water/Methanol Injection, Nitrous & Intercooler Cooling 25 07-11-2007 09:58 PM
Turbo fitment w/ power steering lines smahala1286 Normally Aspirated with bolt-on Forced Induction Powertrain 6 06-01-2006 05:38 PM
Warranty denied on power steering line leak due to exhaust mod rjrmoore Warranty Issues & SOA Problems 156 09-27-2005 05:36 PM
JDM STI Intercooler on WRX - Too Close To AC Line? MrZone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-27-2005 10:22 AM
Local FL RS owners who upgraded to SS Power Steering Lines.. latinskllz South East Region Forum 0 04-07-2003 12:53 PM
