#1 |
Vendor Sales Rating: (69)
These bars will stiffen the chassis of your WRX or STI by connecting the B pillars of the car together. This will also give you a place to mount your harnesses easily and safely.
Speedware Harness Bar - 399.99 Shipped You can add 4pt harnesses to your order. These are full 3" inch wide harnesses. Not the puiny 2" inch. Sparco 4 pt - 179.99 shipped ![]() These are installed by just wrapping them around the harness bar. There is no need to run them into the back seat. We also have longer versions available with mounting options so you can run them to your back seat with or without a harness bar. You can also add camera mounts and fire extinguishers w/ mounts to your order. Speedware Camera mount - 99.99 shipped Sparco Fire extinguisher mount - 69.95 shipped Speedware fire extinguisher chrome - 99.95 shipped Speedware fire extinguisher red - 59.95 shipped Lets us know if you would like anything added to an order or if you have any questions on any of the products. Thank you for your interest and let us know if there is anything else we can do for you. Ben 801.619.1779 parts@rallsportdirect.com aim: rallysportdirect www.rallysportdirect.com |
#2 |
Member#: 29143
Vehicle:2000 IMPreza Camo |
Where do these mount on at the bottom? The rear bolts for the front seats?
Wondering if I can run this with the Do-Luck "hump" bar, which connects onto those,also........... |
#3 |
The speedware bar mounts where the stock seat belt mounts for the front seat. It is underneath the carpet and it requires you to make a small hole to pass the hole through. There is a good write-up of an install on scoobymods.Here is a link to that thread
As for fitment with the Do luck "hump" bar. We have not been able to test fit these together yet. Please let us know if you have anymore questions. Thank you. Ben 801.619.1779 parts@rallysportdirect.com aim:rallysportdirect www.rallysportdirect.com |
