Vancouver Impreza Club
Old 05-24-2004, 08:07 PM   #1
gelgel
Member#: 50522
03 rs
Default another problem~
So, I want to reset the ECU~ I know all the steps, but the problem is, how do you disconnect the negative terminal? Do I just unscrew the nut, and put the thing off or what?
Someone please help me~~
Thanks in advance!
Angel
gelgel is offline   Reply With Quote
Old 05-24-2004, 08:31 PM   #2
kracka99
Member#: 27247
POS Tercel
Correct, undo the nut then pull off the connection from the terminal. Be sure it is not touching the post and step on the brake pedal for a few seconds to totally drain the power and that's it!
Aaron
kracka99 is offline   Reply With Quote
Old 05-24-2004, 11:11 PM   #3
gelgel
Member#: 50522
03 rs
Thanks Aaron~ but got a new problem now~ Just now I was trying to remove the stock airbox~ But one of the bolt is extremely tight that no matter how hard I tried to unscrew it, it won't even move a bit~ What should I do??
Old 05-24-2004, 11:14 PM   #4
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Are you trying to install an intake?
fukamoto is offline   Reply With Quote
Old 05-24-2004, 11:18 PM   #5
gelgel
Member#: 50522
03 rs
yes~ but I didn't even remove the stock airbox~ the bolt is in my way~~
Old 05-25-2004, 12:39 AM   #6
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
If you've got an alarm, have the key-fob ready to disarm the alarm when you put the negative terminal back on.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 05-25-2004, 03:30 AM   #7
gelgel
Member#: 50522
03 rs
LaterZ!
Darren!!
Thanks. I didn't know that the alarm will go on after reconnecting the negative terminal~
Still have no success in taking out the bolt~~
Old 05-25-2004, 03:33 AM   #8
JikJak
Member#: 38225
749 04STI 06CLS55
RangeRoverSport s/c
get someone stronger than u to crank on it
JikJak is offline   Reply With Quote
Old 05-25-2004, 10:27 AM   #9
Penphoe
Member#: 269
Better alarms will trigger - especially if you've got a battery backup siren.
My cheap alarm (that I overpaid for) doesn't have this feature.
LaterZ!
Darren!!
Old 05-25-2004, 06:03 PM   #10
gelgel
Member#: 50522
03 rs
I did, but it's way too tight~ gonna try again tonight~
LaterZ!
Darren!!
mine is the subaru alarm, so will it trigger? Do you know where is the alarm located under the hood? Cause I was reading the intake install instructions from Cobb, and it said if I remove a "thing" (I forgot the name) at the driver side, then it will affect the alarm. And I don't want to kill the alarm~ any idea?
Old 05-25-2004, 06:34 PM   #11
Penphoe
Member#: 269
I don't know if it will trigger or not. Only way to find out is to do it!
Just have the key-fob near by so you can turn it off if it does go off.
LaterZ!
Darren!!
Old 05-25-2004, 07:17 PM   #12
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Just disarm the alarm before doing anything (i.e., unlock the doors) and you'll be fine.
As for the bolt, spray some Liquid Wrench or WD-40 into the threads, let sit for 10 minutes, then try to take it off with an impact wrench. You can borrow mine if you want.
Necromancer is offline   Reply With Quote
Old 05-25-2004, 10:24 PM   #13
gelgel
Member#: 50522
03 rs
Isn't WD-40 flammable? The bolt is under the hood, like around the engine~ is it okay to spray there?
Old 05-25-2004, 11:40 PM   #14
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yes, it's flammable, but you're not spraying flamethrower-style all over the engine. Connect the little straw to the spray can and aim at the base of the nut, below the flange.
Old 05-25-2004, 11:43 PM   #15
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Also, if the bolt is rusted you should probably wipe off the WD-40 after it's off, and put some anti-seize compound on the threads before putting it back in.
Dunno what could be causing that on an '03RS ... but on my car, there's one airbox bolt just underneath the hood scoop drain that gets a lot of water and is a rusty mess (as some of the other guys can attest)...
Anyway, if you wanna meet up I can probably help you out... impact wrench is the best chance to get that bolt out without stripping the threads.
Old 05-26-2004, 12:43 AM   #16
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
I know the answer.. "Turn it counter-clockwise."
Hehehe .. *duck*
Seriously these guys are right. An impact wrench and liquid wrench are the best you can get.. If you strip the head you can drill it out and re-tap/thread the hole. Or try an easy-out device that works as often as not.
Oh and I've always had good success overcoming strength issues by using a 'persuader' bar or box ended wrench. I just hook one on to the end of a wrench I'm working with and it gives me extra leverage. As always your mileage may very and the risk you take is your own. Etc..
420WRX is offline   Reply With Quote
Old 05-26-2004, 01:13 AM   #17
gelgel
Member#: 50522
03 rs
I tried wd40 and it doesn't work~could it be a fake bolt? ~~ here's two pics of the bolt~
anyone knows? It just seems impossible to turn it~
Old 05-26-2004, 01:15 AM   #18
bwco
Member#: 44137
i tried to remove a few airbox of wrx and it's so tight as well, try a longer breaker bar !
bwco is offline   Reply With Quote
Old 05-26-2004, 03:49 AM   #19
gelgel
Member#: 50522
03 rs
Thanks so much for offering help!! But I don't have an impact wrench nor a liquid wrench~
I tried using different kind of tools including the breaker bar~ But still doesn't work!!
420wrx, what's the 'persuader' bar and box ended wrench?
Old 05-26-2004, 04:10 AM   #20
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Ah, now I see. The bolt is tight because the ABS solenoid vibrates around and puts stress on that point.
Anyway, I sent you a PM. You can borrow my dinky 12V impact wrench and hopefully finish the job.
Old 05-26-2004, 10:05 AM   #21
Penphoe
Member#: 269
Oh, that bolt! You'll need to give a little blood to the seized-bolt gods to break that thing free!
Yah, I remember getting that bolt off. She was a tough nut to crack. It's tight for a reason - you do NOT want that thing comming off, lest you lose all brakes!
LaterZ!
Darren!!
Old 05-26-2004, 10:20 AM   #22
420WRX
Member#: 27752
"The Persuader" is any heavy hunk of pipe or wrench you can attach to the end of your ratchet or whatever to get some extra leverage.. You want to make the handle longer.
Only do that if you cannot get an impact wrench.. You don't want to make more of a problem if the bolt is siezed..
Need Help 06 legacy 2.5i problem BlobeyeSTi Mid Atlantic Impreza Club -- MAIC 9 06-04-2010 08:53 AM
A/C Pressure switch 94 Leggy? Need Help DjKlown Legacy Forum 2 06-02-2010 05:42 PM
EJ25 build, need help! rcarlson87 Built Motor Discussion 0 06-02-2010 10:36 AM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
Need help!Need flywheel bulletin from SOA.Please help. RallyeX General Forum Archive 3 06-01-2000 07:57 AM
