05-18-2000, 08:36 AM | #1 |
Member#: 711
Vehicle:1993 Rx7 R1 Yellow |
ECU Reset
What is the correct way to reset my ECU after installing my Minnam Intake?
~Brandon 99' Black RS
05-18-2000, 09:12 AM | #2 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
and remember to simply let it idle... don't touch the throttle when you restart it...
05-18-2000, 10:44 AM | #3 |
Member#: 1267
And then shut the car off; next re-start and go out and drive spiritedly to "re-educate" the ECU.
05-18-2000, 02:03 PM | #4 |
Member#: 775
What happens if you don't shut it off and then start it again? What if you just let it idle, then drive it? Does it not work then?
curtis |
05-18-2000, 03:35 PM | #5 |
Member#: 957
Vehicle: |
Hmmm... an idea, we can do a group ECU reset for my car at the show this weekend, as I am sure someone there is familiar with how to do them the right way. And that will help us newbie ECU reseters.
suby |
05-18-2000, 04:26 PM | #6 |
Member#: 1267
Always make sure the engine is cold (5 hours?) before starting the reset procedure. That doesn't mean you can't disconnect the battery with the engine warm.
05-18-2000, 07:04 PM | #7 |
Member#: 1387
Vehicle:. 2007 STI Black 2001 S2000 Black |
Cant you just pull the sbf2 fuse to reset the ecu?
Keyless entry- reset after ECU reset? | sir_aspen_white | Electrical & Lighting | 1 | 04-22-2003 08:24 PM |
('93-'01) Does an ECU reset change the way an auto tranny shifts? | subymamma | Impreza Forum | 14 | 05-18-2001 11:44 AM |
('93-'01) ECU reset? | littleblue | Impreza Forum | 3 | 05-04-2001 01:00 AM |
('93-'01) ECU reset causing me to run RICH ? | bigbird | Impreza Forum | 5 | 04-10-2001 10:53 PM |
ECU reset for '99 Liberty | Andy_T | Legacy Forum | 0 | 01-23-2000 06:29 PM |
