Old 05-25-2004, 11:09 AM   #1
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
Default How exactly do you "unmarry" an accessport.
I want to buy a guy's accessport, but he doesn't know how to unmarry it. Would somebody please describe the process.
Thank you all.
rex n effect is offline   Reply With Quote
Old 05-25-2004, 12:06 PM   #2
wrxfanboy
Member#: 45013
2004 Impreza WRX
Platinum Metallic Silver
If he's got the port he should have the manual that tells you exactly how to revert back to the stock and "unmarry" the port.
The way I understand it is, you just have to flash the ECU to the base stock map "revert back to stock" and the Accessport is no longer associated with that ECU.
Also FYI, if you go to cobbs website www.cobbtuning.com under the accessport information you can get a pdf copy of the manual and read it in there. I'm still waiting for mine to come in the mail but that is the way I understand it.
Hope that helps.
wrxfanboy is offline   Reply With Quote
Old 05-25-2004, 12:36 PM   #3
bubba03wrx
Member#: 36700
EVO 9
07 GSXR 750
why not just trade computer along with buying the access port
bubba03wrx is offline   Reply With Quote
Old 05-25-2004, 12:50 PM   #4
AgentFixer
Member#: 29230
1972 Buick Skylark
t3h Burgundy B3ast!
Originally posted by wrxfanboy
...The way I understand it is, you just have to flash the ECU to the base stock map "revert back to stock" and the Accessport is no longer associated with that ECU.
I'd have to agree with that. Once the car has been reverted back to the original state, there will be no association with the accessport and your ECU. It's the initialization process in reverse. The instructions are there to help, but if i'm not mistaken, you have to plug together the 2 green test plugs, then plug the appropriate year connector to the semi-transparent plug located next to the test plugs. After that, plug in the accessport and revert back to stock. From there, unplug everything, and it's unmarried, ready to be sold (from my understanding this is the correct way to unmarry it)
AgentFixer is offline   Reply With Quote
Old 05-25-2004, 12:56 PM   #5
w0rXer
Member#: 33222
2003 WRX
Midnight Black Pearl
from the AP User Guide (p15):
Uninstall
Before attempting to uninstall your AccessPORT, please verify that the Test
Mode and Init Connectors are properly attached before proceeding. These
connections are necessary to make whenever uninstalling your AccessPORT.
(Refer to pages 8-9 for instructions on making these connections)
From the Main Menu, highlight [REVERT TO STOCK] and press the Select
button. You will receive a screen confirming that you will be uninstalling your
AccessPORT from this vehicle. Confirm this by highlighting [OK] and pressing
the Select button. You will be prompted to turn the ignition ‘On’ but do not
start the car. Please the Select button quickly after turning the Ignition ‘On”. A
progress screen will appear. This may take several minutes. The AccessPORT will
be uninstalled from the vehicle once the [AccessPORT DONE] screen is
displayed. NEVER disconnect the AccessPORT from the vehicle when
performing this task until you’ve received the [AccessPORT DONE] screen.
Remember to remove the Init Connector and disconnecting the Test Mode
connectors before driving the vehicle.
w0rXer is offline   Reply With Quote
Old 05-25-2004, 01:01 PM   #6
rex n effect
Member#: 15289
02 wrx pollen silv
Thanks all. I got a copy of the users guide.
Can an accessport that was bought as an upgrade be divorced in the same manner?
Old 05-25-2004, 04:34 PM   #7
wrxfanboy
Member#: 45013
2004 Impreza WRX
Any accessport can be unmarried with the ECU it is associated with so long as you follow the process above.
It's basically a security thing so one of your friends doesn't buy the port and start flashing ECU's for everyone and their brother.
Cobb would be out a lot of money if they allowed that don't you think?
Old 05-25-2004, 09:03 PM   #8
03WRXMA
Member#: 35081
2012 WRX
Thats a good question!
Because an AP bought as an upgrade may be associated with a particular ECU since it costs less, but its unlikely Cobb would do this as it seems rather complicated.
03WRXMA is offline   Reply With Quote
Old 05-26-2004, 05:19 PM   #9
oman
Member#: 9293
java black pearl
Once an upgrade AccessPort is married to an AccessECU reflashed ECU it becomes identical to a normal AccessPort.
Basically it allows the guys who have a reflash already to get to the same point as someone who paid full price without having to pay for the reflash over again.
oman is offline   Reply With Quote
Old 04-14-2009, 08:22 PM   #10
theblackstallion
Member#: 187225
2007 WRX STI
Obsidian Black Pearl
I'm selling my accessport, when I unmarry it, I see that you connect it to the car and go to the unistall blah.... when I flash the ecu and unmarry it..will the settings on my ecu go back to the stock settings? or can I just sell it to him and then let him unmarry it with his ecu???
theblackstallion is offline   Reply With Quote
Old 04-14-2009, 09:35 PM   #11
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
you need to unmarry it or youre selling him a paperweight
elevenpoint7five is offline   Reply With Quote
Old 04-19-2009, 08:08 PM   #12
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
www.ClintonRacing.com
Uninstall
Alright I need to unmarry my APv2 from my '04 STi in order to update the firmware (apparently my AP is really old...). I remember having to attach the test connectors when installing it, but there are couple of things I need help with.
1) What color are the test connectors? Green? And it is on the drivers side correct?
2) What are the init connector that the user guide (bolded above) is referring to?
3) My AP does not say "Revert to Stock" only "Uninstall"... are these the same, because when I select "Uninstall" it gives me a warning that "Uninstallation will remove all maps."... This doesn't mean it is going to erase all my maps does it?
Thanks
generalee69 is offline   Reply With Quote
Old 04-21-2009, 10:17 AM   #13
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
bump.
Old 04-21-2009, 11:01 AM   #14
nme187
Member#: 117763
Yes and Yes
The 02-5 WRX's only had the Init connectors
Thanks
Revert to stock is on the V1 AP's not V2. V2 AP says "Uninstall"
Cheers
nme187 is offline   Reply With Quote
Old 04-21-2009, 11:10 AM   #15
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
Perfect, thank you much!
Old 04-21-2009, 11:26 AM   #16
nme187
Member#: 117763
Yup no problem
Old 04-26-2009, 01:46 AM   #17
KillerRabbit
Member#: 184772
2004 WRX
World Rally Blue
So basically if its not unmarried, its a throw away item?
KillerRabbit is offline   Reply With Quote
Old 04-26-2009, 11:29 AM   #18
richbrown06
Member#: 185435
2008 STI
blue/gold
I have a question, is there any way to unmarry an accessport that was married to a car but that car got tottaled and took to the junk yard?
richbrown06 is offline   Reply With Quote
Old 10-21-2009, 11:53 AM   #19
Borjaq
Member#: 4812
04 STi
Blk
I'm taking a guess at this, but if you can get access to the car and can get power to the ECU and hook up your AP then you should be able to unmarry it. I have no real idea though since I don't have AP yet.
Borjaq is offline   Reply With Quote
Old 10-25-2009, 05:06 PM   #20
k2snow
Member#: 10449
03 Legacy BH
I'm having a similar problem I have an ap1 but will not install. it always gives me the error message that says incorrect ecu halting opperation. Does that mean my ap is still married onto another vehicle?
k2snow is offline   Reply With Quote
Old 01-07-2010, 12:59 AM   #21
Scooby-King
Member#: 180499
2007 SRT8-Cherokee
2008 Sierra Denali
You can send the unit to Cobb and have them unmarry it manually IIRC.
Its not cheap, and you need proof that it wasn't stolen or anything like that lol
Scooby-King is offline   Reply With Quote
Old 01-07-2010, 08:26 PM   #22
Cobb Tuning
Member#: 4803
The old "upgrade" AccessPORTs will not work on a car that didn't have one of the VERY OLD AccessECU flashes. These units would only work on cars that were so equipped and no others.
That said, if you are talking about a V1 to V2 upgrade, these AccessPORTs are the same as any other so you can uninstall them and sell them on, trade them for beer or what have you and they can be installed on another car.
When you uninstall the AccessPORT it writes the stock map that was previously on the ECU back to the car, this is part of the uninstall process. DO NOTE: This is not the same as flashing the "stock map" to the car, you have to go through the uninstall process to "unmarry" the AccessPORT. Once this is done, the ECU is back to 100% stock and the AccessPORT can be installed on another car.
We are able to "relicense" a unit that is still installed on a stolen or wrecked car but we do need to see 1. Proof of purchase AND/OR 2. A police report stating the car is wrecked or stolen or an insurance claim stating the car was wrecked or stolen. Otherwise, the relicensing fee is $395.
Travis
COBB Tuning
Old 02-10-2010, 09:22 PM   #23
erikkellison
Member#: 67412
2013 WRX
I bought an AP that was not unmarried from the seller's car. I just shipped it back to him to have him unmarry it, and I want to help him unmarry it (he asked for directions). If he has a custom tune on his car currently that is NOT a Cobb AP map, will he lose it? It's a V2 for the 2002-2005 WRX. He does not have his tune personally - it is with his tuner. Can he do the uninstall without removing the custom tune map on his ECU, or will the uninstall process flash the ECU to stock no matter what?
TIA
erikkellison is offline   Reply With Quote
Old 02-11-2010, 03:52 PM   #24
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
Yes he will lose it, thats the reasoning behind marrying it to a car, so you cant just flash as many cars as you want with one map
Cards2323 is offline   Reply With Quote
Old 02-11-2010, 05:02 PM   #25
erikkellison
Member#: 67412
2013 WRX
Default Re: How exactly do you "unmarry" an accessport.
I meant if it's a custom non-Cobb tune, like open source? Still lose it?
How exactly do you disconnect the O2 sensor? Please hurry. GreasyJoe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-15-2008 08:40 PM
How exactly do you do this? (Modified Koji mod) Jackie Interior & Exterior Modification 6 10-18-2006 04:30 PM
Do you have an AccessPort? Can I borrow your '03-'04 init connector Massive Southern California Impreza Club Forum -- SCIC 4 04-11-2006 03:25 AM
How exactly do you splice a wire? STIRS Newbies & FAQs 6 06-22-2003 09:10 PM
How exactly do you do smoke the headlights? Die Civic Interior & Exterior Modification 10 09-26-2001 09:12 PM
