Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-17-2000, 06:43 PM   #1
Spectre23
Member#: 311
2013 STi
CBS
Unhappy Idle problem after ECU reset
I went down to Las Vegas for Import night at the drags down there (which I won). Since Vegas is 1/2 the altitude I am at home, I figured I would reset my ECU. What could it hurt right? Well now my car idles at about 1750 RPM ever since I did it. I tried reseting it again when I got home but it still idles really high.
What could be wrong?
Spectre23 is offline
Old 05-19-2000, 12:42 AM   #2
OBSS
Member#: 1421
1997 OBSuperSport
Arcadia Green
Lightbulb
Check the connections on every hose, if you haven't done so already.
The next would be any “aftermarket” electronics, including stereo. Check for loose wire, bad grounds, etc..
Finally, do an ECU reset by disconnecting you negative terminal for approx. 30-45min. Reconnect, start the car, and let it idle without touching the throttle at all.
After about 15min of idle, turn off the car, wait(count to ten), and restart.
Hope this helps if you haven’t already tried.
OBSS is offline
07 STI STAGE II(PDX Maps) - Stutter Problem after ECU Reset subbie03 AccessPort 3 02-11-2009 03:10 AM
problem after i reset my ecu burtonboy759 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-02-2008 08:01 PM
Problem after ECU reset Jonathan_Yi Normally Aspirated Powertrain 4 06-25-2005 06:06 PM
Stock Alarm problem after ECU reset Longitude Car Audio, Video & Security 6 01-10-2001 12:20 AM
Problems after ECU reset Gorio Normally Aspirated Powertrain 10 12-05-2000 06:49 PM
