Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-17-2000, 03:22 PM   #1
JF
Member#: 14
Question Anti-Lift kit = Alignement?
For those of you who installed the kit, did you have to align the front wheels? Did the camber and toe change? On the MRT site they only "suggest" to align the car which is why I ask.
If you did so, did you keep the same settings as without the anti-lift kit?
Thanks for the info,
JF
Prodrive, 20mm, F&R strut tower, etc etc
JF is offline
Old 05-17-2000, 05:35 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I would think that you'd absolutely need to align it afterwards since it changes toe, camber, and castor (which is it's point afterall) all at the same time just from installing it. Your can may drive weird without an alignment and you'll get funny tire wear eventually.
8Complex is offline
Old 05-17-2000, 07:17 PM   #3
JF
Member#: 14
Smile
Yeah, that's what I thought. You have that kit as well?
Thanks for you time
JF
JF is offline
Old 05-17-2000, 07:30 PM   #4
Impy
Member#: 489
Post
Is it help full on a relatively stock RS?
Impy is offline
Old 05-17-2000, 07:44 PM   #5
JF
Member#: 14
Post
I cannot answer this since I don't know exactly to what level it will change the car. A sure bet would be to start with the rear sway bar, then the suspension. That's when you will see the biggest difference. I'll be able to tell you more in a couple of days when it is installed
JF
JF is offline
Old 05-17-2000, 07:58 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I don't have the kit but I've been thinking about it. Only problem is that it'd up me in classes at autocrosses from STS to Street Prepared so I didn't get them since it is only my first season and would have NO chance in hell.
8Complex is offline
Old 05-17-2000, 08:03 PM   #7
Tyrmeltr
Member#: 667
2013 Impreza WRX 5D
Plasma Blue Pearl
Post
Not to condone cheating, but do you think anyone would notice your anti-lift kit at an Auto-X? If I caught something like that at an Auto-x, I wouldn't protest because I don't think it's a make or break part, in regards to being competetive.
Tyrmeltr is offline
Old 05-17-2000, 08:07 PM   #8
JF
Member#: 14
Post
And it would complement your links
[This message has been edited by JF (edited May 17, 2000).]
JF is offline
Old 05-17-2000, 08:09 PM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
LOL true... BTW, I hate the MRT links FYI. My front ones creak even when fully greased and I've had the rears but they are still no comparison to solid links. (my review of links will be updated soon as well as my homemade front links being published ).
8Complex is offline
Old 05-19-2000, 12:39 AM   #10
JF
Member#: 14
Thumbs up
Okay, time for a review. The anti-lift kit is in and so far I like it. It's not like it will transform the car though. I already had a tight handling with the (original) Prodrive setup. The car wouldn't lift or dive that much compared to stock suspension. Now, with the AL kit, the car won't lift that much (if not at all) under hard acceleration (1-2-3 gears). When braking, the nose feels tighter but will still dive if you hit the middle pedal too hard. Under cornering, it seems that the outside front tire scrub a bit more making the tail easier to skid. I suspect the weight transfer being different. All this was done on very familiar roads and curves (wet) so it's not so much psychological as some would say. The fitting took around 50 minutes and there isn't much difference in the car's alignment or stability. On the higway, I could feel the wheel floating a bit more and maybe the different castor has to do with it. I'll have the alignment checked soon just to make sure. So far so good, this is probably another good bang for the buck item handling-wise second to the 20mm rear sway bar. For 165$US it's hard to beat!
Cheers,
JF
JF is offline
Do I need an alignment after Anti Lift Kit install? Mr Nice Guy Brakes, Steering & Suspension 15 01-04-2010 04:14 PM
To Anti-Lift Kit..? Or, Not to Anti-Lift..? PSRS (+Video) krylon General Community 45 11-07-2009 10:10 PM
VA: Whiteline Anti Lift Kit w/ caster kit richy_21 Suspension/Brakes/Handling 26 09-22-2007 12:25 PM
alignment after anti-lift kit tucker63 Brakes, Steering & Suspension 4 08-14-2003 03:44 PM
Alignment changes with anti-lift kit DigDug Brakes, Steering & Suspension 0 07-20-2001 03:41 AM
