Old 05-25-2004, 07:16 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default im assuming yes but does a turbo have to sit flat?
i cant seem to get it to sit level i dont know what the deal is maybe if i drop the hanger down for the DP and let it drop down a lil in the front i dunno
but if i leave it at at little slope, id say 10 degrees is that bad for it?
alex
Old 05-26-2004, 05:25 AM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
You can have them at any angle you want really. Ever seen the setup on an rx-7? They sit kinda upside down towards the bottom of the engine. Only thing you need worry about is the gravity feed for the return line.
Drac9 is offline   Reply With Quote
Old 05-26-2004, 08:36 AM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
it should be fine
thanks
i wanna call FP just to make sure but thanks drac
Old 05-26-2004, 09:20 AM   #4
8Complex
Member#: 922
04 FXT
Red
10° isn't bad. You need to be concerned about thrust bearing wear at angles higher then that, from what I've been told.
Old 05-26-2004, 11:09 AM   #5
Unsung Boxer
Member#: 37196
button problems
Unsung Boxer is offline   Reply With Quote
Old 05-26-2004, 11:09 AM   #6
Unsung Boxer
Member#: 37196
button problems
Old 05-26-2004, 11:09 AM   #7
Unsung Boxer
Member#: 37196
***? more stupid browser...
Old 05-26-2004, 11:10 AM   #8
Unsung Boxer
Member#: 37196
any angle i believe is fine. Most turbos are gravity feed from the oil return, so ya want to make sure that is angled downward, or you might get oil backing up. I dont know that it was cause a problem, but its always a good idea to have it flow directly back into the pan (or wherever you are dumping it)
As far as thrust bearings go... you are using a ballbearing turbo right? If not, I can't imagine it making much of a difference. I see them mounted every which direction... but then again, sounds like 8 might be onto something. Check into it more if your concerned.
-Jake
Does the MAF sensor have to be flat? WRXEcho Factory 2.0L Turbo Powertrain 5 06-20-2008 11:09 PM
the midwst does suck.....but only if you have to drive through it... The Tree Off-Topic 12 09-02-2006 01:17 PM
WTB: cheap but working egt.... anyone have one sitting in the corner? psyber_0ptix Mid Atlantic Impreza Club -- MAIC 0 11-10-2005 03:04 PM
What do you do when you have to sit on a public toilet? Ravanux Off-Topic 20 06-02-2005 01:57 PM
Can't remember but, does the GT have... sovereignmk1 Legacy Forum 15 02-07-2003 12:44 PM
Message Board Statistics All times are GMT -4. The time now is 10:21 PM.
