Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-17-2000, 07:39 AM   #1
Member#: 48
1999 Impretza 2.5
Question AFC numbers for replaced intake
When you guys put in one of those nifty AFC with all the fancy readouts, what numbers do you put in. What range of control do you have?
What I have is a stock intake from MAF to throttle body, with a MRT filter setup. Id like to replace the rest too, but, the AFC everyone uses is illegal in STS rules. So I can get my Subaru guys to make some adjustments to the stock ECU, but they need to know what it needs. So if any body can tell me, I can tell them. And how would you go about tuning it from there. Do you all use some kind of monitoring setup, or do you use eyes/ears/buttometer method. What exactly are you looking for?
Thanks for any help.
Silver 99 RS
Eric is offline
Old 05-18-2000, 06:20 AM   #2
HRE | giulio
Member#: 481
your problem is that every settup requires different numbers. you should borrow an SAFC, then tune it. record the numbers. take the safc off and then give the numbers to your ecu guru.
you can use an A/F meter (best way) or the 'blue wire mod' on the afc to tune.
HRE | giulio is offline
Numbers for tuned spt intake prspect06 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-20-2008 05:09 PM
Part number for OEM wrx intake? Eyedoc Orlando Normally Aspirated Powertrain 5 05-25-2007 01:12 PM
Replace RS blackbox for local intake Slamsitin New England Impreza Club Forum -- NESIC 5 01-05-2006 12:09 PM
part number for wheel well intake hole? Endlesshine Mid Atlantic Impreza Club -- MAIC 10 08-06-2002 04:32 PM
Dyno numbers for the Ganz Flow intake? ITR&RSGUY Normally Aspirated Powertrain 3 07-19-2001 02:20 AM
