Old 05-26-2004, 12:58 AM   #1
OB2
Member#: 51500
1999 impreza rs-t
sylver
Default Link VS 99 RS-T???
My S-AFC and ITC do not do the job anymore and i want to buy a Link stand alone and i want to now if have to keep my fuc*** MAF if i get it???
Can someone give me the link, for the officila Link site???
Please give me all the Info you can tell me!!!
OB2 is offline   Reply With Quote
Old 05-26-2004, 01:44 AM   #2
Unsung Boxer
Member#: 37196
the first thing u need to do is figure out what you are trying to accomplish.
If you hate MAF so much, you can certainly get the MAP based ECU... im not sure if the wiring harness is the same.... but in all honesty MAF is easier to tune.
More importantly, Link will not meet OBD2 requirements, therefor you will never pass emissions.
Emanage is a great alternative... can fulfill both SAFC and ITC functions plus more for less $$$. Link is like 1200 bucks, and it does some interesting things, but i dont know that its necessary/appropriote for a daily driver OBD2 vehicle.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 05-26-2004, 01:52 AM   #3
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
All of this info I believe can be searched but here goes
I'm pretty sure the Link Plus has a internal MAP
Official site can be had by doing a google search on Link USA. Good luck, there is tons of info on the Link Plus here, so you can try this site as well
benjaminetanyahoo is offline   Reply With Quote
Old 05-26-2004, 03:06 AM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
im an idiot as far as i know
Old 05-26-2004, 03:17 AM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
standalones are a pain in the butt, stay away from them.
subiekid is offline   Reply With Quote
Old 05-26-2004, 03:19 AM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
lol y
Old 05-26-2004, 03:21 AM   #7
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Haaaa, and he has a TEC III
Old 05-26-2004, 03:50 AM   #8
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
unsung, do you use the emanage? how do you like it? i see you live in WA and have the same dilemma as me, engine management while keeping emissions compliance. i wanted to use it with the J&S but after hearing about the learning around the emange stuff and the cel stuff im kinda reluctant
Derk1127 is offline   Reply With Quote
Old 05-26-2004, 03:54 AM   #9
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Originally posted by White 2.5rs
link plus does not have internal map as far as i know
For someone who complains about not answering the damn questions unless you know the answer you sure do talk a lot. The link has an internal 2 bar map sensor. Hence the need to run the vacuum line to the ecu. You can also use a an external 3bar gm map sensor as well. Please refrain from answering when you don't know the answer for sure. It's the same curtesy you ask of everyone else so follow your own advice.
Also, to answer the original question you do not need your MAF Sensor anymore as the link is a speed density ecu so it uses the map sensor to figure out the amount of air coming in. In fact- all those sensors on the strut tower there can be removed as well.
Drac9 is offline   Reply With Quote
Old 05-26-2004, 04:38 AM   #10
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
alright fine by me
ps the only reason i thought that was because of the amount of poeple purchasing 3 bar sensors for higher HP apps but youre right ill stop responding to posts
Old 05-26-2004, 06:36 AM   #11
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Geez, I don't think it's that serious is it... We are all here to learn aren't we, I mean I can honestly say I have learned more in a month being part of this board by asking the stupid questions, but hey that's just me
Old 05-26-2004, 08:24 AM   #12
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
I have emanage in my car (NA at the moment).
It works great with no CEL. I can feel and read furl changing via ODB2 logging.
I have only tried modifying timing +-5 so I havent felt a huge difference. The ignition is wired through the emanage so it must be woring for the car to run
Wiring was very straightforward and I would be glad to help anyone with it if they get into trouble. I'll let you all know when the turbo goes on as to how easy it was to get it running pretty well. I have a m300 wideband that I plan on logging through the Emanage's boost sensor port. (Many have done this as the boost sensor (MAP) is 0-5v and can be logged without beigh referenced in maps.
I have a 99 so I am MAF based.
Todd
Hitokiri is offline   Reply With Quote
Old 05-26-2004, 12:48 PM   #13
Drac9
Member#: 9861
I was simply pointing out that he gets mad when people do the same thing to him. These forums are a much better technical resource if people only post when they are sure they know the right answer when it comes to a specific question. That being said, I might have been a bit nicer about it. Anyway, there are no stupid questions, just try to be correct if you are going to answer any.
Old 05-26-2004, 01:26 PM   #14
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
The Link Plus comes with a built in 3 bar MAP sensor giving you the capability to tune up to ~29psi. If you are worried about OBD-II testing for emissions I do not recommend the Link. But other than that, its a great standalone if you can or know someone that can tune it.
WRC 555 is offline   Reply With Quote
Old 05-26-2004, 01:46 PM   #15
Drac9
Member#: 9861
no, it has a built in 2bar- but can use an external 3bar.
Old 05-26-2004, 02:30 PM   #16
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Techinically its a 3 bar. Your forgetting about atmos. pressure. So it is 2bar in boost.
Old 05-26-2004, 03:18 PM   #17
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
So no one mentions the hydra because??? .... but to be honest for guys with mild to mid mods... i would wait for the reflash to come out if it ever does..... /sigh
also i agree with Drac... White RS has been a little lippy ..
HOK is offline   Reply With Quote
Old 05-26-2004, 06:28 PM   #18
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
A reflash would love everything I think, I hope I-speed comes out with it or somebody does....
Old 05-26-2004, 07:43 PM   #19
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
no, im sure that it is a 2 bar, counting atmospheric, letting u run up to ~14.7psi
Old 05-26-2004, 07:44 PM   #20
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
if it was 2 bar, then how in god's name is WRC 555 running more than 14.7 with a Link Plus? Unless he has the optional 3 bar chip installed.
Old 05-27-2004, 01:40 AM   #21
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
OPTIONAL 3 bar chip installed.
Old 05-27-2004, 01:48 AM   #22
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Maybe That would be strange because the 4 other Link Plus's I've tuned have all had internal 3 bar MAP sensors and were purchased from different places without the buyers requesting that option.
Old 05-27-2004, 01:50 AM   #23
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
I say we just fight about it
Old 05-27-2004, 02:04 AM   #24
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
it lists it as an option on links site, an external 3 bar sensor
and it mentions the stock one is a 1.5 on the LEM <link1?>
Porsche Cayman S vs 99 RS subiedreamin Off-Topic 39 03-12-2006 01:37 PM
99 rs coilpack vs 01 rs coilpack smacksube Electrical & Lighting 1 07-13-2003 03:45 PM
BOV return vs 99 RS MAF JST Normally Aspirated with bolt-on Forced Induction Powertrain 8 04-02-2003 01:55 PM
98 RS guys! - Link vs Utec vs Exede vs flash buraddo Engine Management & Tuning 4 02-23-2003 12:59 PM
Spoiler Dimensions, 98 vs 99 RS ilmaestro Interior & Exterior Modification 4 03-29-2002 12:34 PM
