Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-17-2000, 08:46 AM   #1
ScoobyDriver
Member#: 195
2001 BH9
Question Sway Bar Modification (opinions please)
Hi,
Like always my engineering knowlege gained from 3 years of college before switching majors is spuring me on...
My friend just took delivery of his Whiteline adjustable sway bar. Now under close inspection this bar happens to be the same diameter as the sway bar I got from SPD last year. The major difference are the 3 holes on each end of the bar.
Now to the question. What if I drilled 2 more holes in the same configuration into my bar? One would think this would yeild the same results, True?
Thanks,
Shane Kullman
'98 RS Red
ScoobyDriver is offline
Old 05-17-2000, 10:03 AM   #2
rsfreak
Guest
Member#:
Post
i dont see why it wouldn't work....give it a try....just drill out one of the other holes...prefferibly the 22mm setting and se if it works..if it does then drill out the other one and then you have yourself an adjustable bar....
Old 05-17-2000, 10:12 AM   #3
brandon
Member#: 1183
09 Legacy, 76 Mini
64 Lotus Elan, 70 Elan +2
Post
Just make sure you've got enough meat to drill the new holes. There will be a reasonable amount of stress in that area, and you definitely would not want it to break in a high speed corner. If it looks beefy enough though, go for it. As an added precaution though, you could always make up a few plates for the outboard side. That would strengthen it up.
brandon is offline
Old 05-17-2000, 04:50 PM   #4
uktena
Member#: 1267
Post
Since you're in engineering school; you might want to check with a metallurgist(sp?). There is the potential for great differences.
uktena is offline
Old 05-17-2000, 07:05 PM   #5
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Post
It's funny you mention this because just Yesterday I was thinking the SAME thing...tempted to try it and see...
Scooby South is offline
FS : 04 STi OEM Coilovers and Sway Bars suby300 VIC Private Classifieds 5 07-18-2010 10:15 PM
FS: Whiteline 22mm Adjust. Rear Sway Bar *CHEAP* SubaruCrazy Suspension/Brakes/Handling 11 06-11-2010 12:58 PM
yet another sway bar question: opinions needed. the_poser Brakes, Steering & Suspension 9 04-07-2006 08:32 PM
modifing the stock sway bars rsotak Brakes, Steering & Suspension 10 04-27-2004 03:07 PM
Whose sway bars should I get? (and front lip opinion needed) rkkwan New England Impreza Club Forum -- NESIC 5 08-03-2001 03:22 PM
