05-26-2004, 10:26 AM | #1 |
Member#: 57709
Vehicle:97 Legacy 2.5 GT green |
Head bolt tightness
When turboing a NA subaru or adding more boost to an already turboed subaru should the head still be tightened to stock specifications or should it be tightened more for the added psi?
05-26-2004, 09:35 PM | #2 |
Member#: 9436
Vehicle:05 Saab 9-5 Aero |
ALWAYS USE THE STOCK SPECS FOR STOCK BOLTS!!! someone who makes a lot more money than you and I (combined) and is a lot smarter, determined exactly what the "stretch" point is and waht the "yield" point is... over torque the bolt and it yields... doesn't mean it breaks, just that the head is not properly clamped under all conditions and the gasket fails quickly. Aftermarket bolts/studs (ARP) are a different story, use their specs.
05-27-2004, 12:00 PM | #3 |
Member#: 57709
Thanks, I used factory specs and just wanted to check.
ARP head studs V's OEM sti head bolts | bugeyes | Built Motor Discussion | 93 | 05-08-2020 12:33 AM |
WTB: ej257 gasket kit, ARP head bolts and case bolts | 69_Lex | Private 'Wanted' Classifieds | 3 | 02-20-2008 10:38 AM |
Can I reuse block bolts/head bolts | Tattoo Collector | Normally Aspirated Powertrain | 19 | 01-22-2005 01:35 AM |
head bolt tightness | Barticus | Pre-2002 Factory Turbo Powertrain | 5 | 07-04-2004 09:56 PM |
Head Bolts & Cams Bolts Torque Specs | Imprezd | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 03-20-2003 07:30 AM |
