Old 05-26-2004, 10:41 AM   #1
17cTSi
Member#: 60256
Default Need help: just got 02 and CEL makes the car run like crap
I just took delivery of the car and i was getting on the autobahn to go home and at WOT the car felt like it hit fuel cut and the CEL came on. It would feel like fuel cut everytime i hit over about .12 on the gauge in 3rd 4th or 5th. The dealership i got it from told me it was slighlty modified but all i noticed was a short shifter hacked air box and a blue colored turbo inlet pipe. After getting home i took a more indepth look and found an MBC. Can this be making the car hit fuel cut and bring the CEL on? I had the dealership over here run the code and they said it was not firing right in 2 of the cylinders. And it also had a boost controller code. I want to return it to factory controlled, but how. My TSi was just an electronic valve with 2 nipples on it. I did not have to remove it from the engine i just left it in. Could it still be in the engine bay and i just have to reattach it to the housing? I think i might just run the pressure line right on to the wastegate actuature. No boost but no risk of something ****ing up, until i figure out how to hook it back up.
17cTSi is offline   Reply With Quote
Old 05-26-2004, 10:42 AM   #2
17cTSi
Member#: 60256
Oh one more thing. I had the dealership clear the CEL and it ran perfectly fine until the boost got up again in 3rd and then the fuel cut thing happened again, and the CEL came back on.
Old 05-26-2004, 01:59 PM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
If you were boosting to .12 bar then it probably was fuel cut. There should be the factory boost solenoid still in the car. It is under the black plastic plate just behind the airbox. It is attached to the metal frame that the plate attaches to. For the short term (or long term if the FBC is removed) just turn the boost down on the controller.
mbiker97 is offline   Reply With Quote
Old 05-26-2004, 07:20 PM   #4
shinsain
Member#: 51745
LIKE A
BOSS
dude, take the freakin MBC off so you don't blow the damn thing up, reset the ecu and check the turbo inlet pipe and intake area for loose vacuum hoses.
oh, did i say take the freaken MBC off? yeah, do that too.
shinsain is offline   Reply With Quote
Old 05-26-2004, 07:22 PM   #5
shinsain
Member#: 51745
LIKE A
BOSS
oh, one more thing, if the car isn't firing right on two of the cylinders, and its got an MBC in it, and its hitting fuel cut, and whatever else, you have NO idea what the prior owner did to it!!!
find some way to get the dealer to repair it somehow. you just paid for a car that could have a smoked engine in it, and they did it to you! ARGH!!!
CEL p0304 car runs like crap anthony27 Service & Maintenance 1 10-22-2008 03:19 PM
car running like crap alptekin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-11-2004 08:01 PM
Finally got to stage 4, oh nevermind its running like crap Dirty B Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 07-21-2003 12:26 PM
HELP...car running like crap... Samirr76 Tri-State Area Forum 22 03-26-2003 04:59 PM
Anybody's car run like crap after... Tokay Normally Aspirated Powertrain 1 07-17-2002 10:32 PM
