Old 05-26-2004, 12:21 PM   #1
Lo0mis
Member#: 12469
2000 2.5 RS
BRP
Question Which line is the fuel return
So which one is the fuel return? And what is the other line?
Please go here for the picture:
http://www.rs25.com/forums/showthread.php?t=16228
Thanks.
Lo0mis is offline   Reply With Quote
Old 05-26-2004, 01:45 PM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
#1 is return, #2 is vent- goes to the charcoal canister I believe
Drac9 is offline   Reply With Quote
Old 05-26-2004, 02:31 PM   #3
Lo0mis
Member#: 12469
2000 2.5 RS
BRP
Cool, thanks. So how do I plumb in the vent to my custom rail/parallel line setup? Just cap it off?
Old 05-26-2004, 02:45 PM   #4
Drac9
Member#: 9861
If you follow that line it goes to the purge valve under the intake manifold. I would just leave it plumbed in if possible. Check www.scoobymods.com for more info.
Cruise Lines, which one is the nicest Mud Pig Off-Topic 46 01-08-2007 06:17 AM
which side of the line is the "IN" side of rrfpr? darioc Normally Aspirated with bolt-on Forced Induction Powertrain 1 12-03-2004 04:00 PM
where is the fuel pressure regulator line? wrxtrev Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-25-2003 02:23 PM
Getting the fuel lines off the Fuel filter t.rod Service & Maintenance 6 02-16-2002 05:07 PM
Shiv..Where did you tie into the fuel return line for the Bell RRFPR? mjos Technical Forum Archive 6 05-08-2000 09:55 AM
