Old 05-26-2004, 12:58 PM   #1
SpamMansXe
Member#: 15920
1999 White Mock 22B
2014 Plasma Blue GR STi
Default If i get an STi shortblock...what else needs to be changed?
So i was going to be getting another ej22t to replace mine...but there are all these sales going on for STi shortblocks. Is there anything else needed to do that swap. With the ej22t it was a direct swap and all that was needed to change was the shortblock and i cuold run with everything else from the original ej25. Thanks for any help!
Steve
SpamMansXe is offline   Reply With Quote
Old 05-26-2004, 01:34 PM   #2
Aphex
Member#: 146
'16 WRX Limited
as far as I know the only thing you need is the STI water crossover pipe to clear the second crankcase breather on the block. But some people, I think white2.5rs, modified their stock water pipe to work.
the STI pipe is only about 100ish
Aphex is offline   Reply With Quote
Old 05-26-2004, 03:21 PM   #3
SpamMansXe
Member#: 15920
1999 White Mock 22B
can i run the STi block with 2.5rs heads? Can i run a turbo kit for a 2.5RS block on an STi block?
Old 05-26-2004, 03:33 PM   #4
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
What happened to your ej22t block by the way? Just want to replace it or did the engine fail? Just curious....
Good luck
Benny
benjaminetanyahoo is offline   Reply With Quote
Old 05-26-2004, 03:34 PM   #5
SpamMansXe
Member#: 15920
1999 White Mock 22B
gotta take it apart...but it failed w/o a turbo on it...i think the heads were damaged from before.
Old 05-26-2004, 04:02 PM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Steve
if u use wrx pipes ull need
wrx xmember
wrx uppipe+spacer
wrx dp
possibly a wrx exhaust
yes the heads will work i recommend new springs+retainers <stronger, not just new>
wrx WP+thermostat cap <not sure if u can get away w/ just the thermostat cap>
a wrx wagon front sway <not sure if u need the endlinks for that or for your 99>
word
Old 05-26-2004, 04:05 PM   #7
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
To answer your questions, Yes.
Just make sure you prepare your N/A heads for boost.
Wedge is offline   Reply With Quote
should you get STi Coilovers if you get an STi Tranny? wrx03.4wz Brakes, Steering & Suspension 6 03-03-2008 09:11 AM
Future plans for EJ257 hybrid...what needs to be changed. CoolRex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-05-2007 02:03 PM
So at 80K miles, what bushing need to be changed? qtr_wrx Brakes, Steering & Suspension 5 11-19-2006 11:25 PM
say i wanted an sti shortblock...what heads could i use White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 29 10-19-2003 10:19 PM
If I get an EVOVIII am I still allowed to hang out here? blitzpb Southern California Impreza Club Forum -- SCIC 14 01-29-2002 12:01 PM
