Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 08-01-2000, 10:00 PM   #1
Andrew
Member#: 1170
2005 STi
Exclamation Tranmission fluid leaking!
I've been noticing that my car has been leaving brown puddles. I didn't know if it was maybe my other car that left it before it, or if its new. Today I checked under the car...I see liquid on the oil tank, the headers, the carb... its everywhere... I thought at first it was oil, but upon further inspection, i foudn it to be tranmission fluid. How'd that start leaking? I have no clue. I'm gonna call up my dealership tomorrow and see if I can get it checked out soon. Anyone else had this problem before?
MY00 RS, Sedan, Automatic. No mods besides the sound system....
Andrew is offline
Old 08-02-2000, 02:12 AM   #2
98Gal
Member#: 1709
1998 Impreza 2.5rs
Black - SOLD
Post
Have you ever had a "power trani flush" ? I had one done once and awhile afterwards the lines came loose and leaked. All they had to do was tighten the lines back up. I never noticed any puddels ... but i did however notice the trani fluid all over the place underneath the car when i went to change my oil.
Hopefully it's just a simple fix for you also.
Hope this helps you out
98Gal is offline
Old 08-02-2000, 09:05 AM   #3
Joe Hogan
Member#: 699
2002 golf TDI
Post
Transmission fluid is Pink?? Not brown. A MY00RS should still have realively clean fluid. Are you sure it is not engine oil or differential grease??
Joe Hogan is offline
Old 08-03-2000, 01:42 AM   #4
Turbotegra
Member#: 1389
2007 IS350
05 VFR 800 ABS
Post
Automatic transmission fluid is pink. Might be motor oil.
Turbotegra is offline
Old 08-03-2000, 06:23 PM   #5
Andrew
Member#: 1170
2005 STi
Have a Nice Day?
First off, no on the power trani flush
Second, it has to be the transmission fluid. I got a paper towel, wiped over the puddle (it is fairly small, which means its leaking pretty slowly-thanksfully). Then I took out the dipstick, wiped that too...Hm...they are both brown, but one is musch lighter then the other-hence cant be oil. Next thing I checked was the transmission fluid,
ok forget all that, just went down and checked again, looked at the cap (my neighbor said it might be transmission fluid)-but alas it is not, this is however-brake fluid. Not a good sign huh? My brakes have been working fine, I havne't done anything with them, only thing REMOTELY close to do with brakes that I have done is color the calipers yellow, but that wouldnt cause a leak near the engine.....Hm...Well I'm taking it in on thursday anyways so that Subaru can deal with it.
Andrew is offline
Old 08-03-2000, 08:51 PM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
2001 2.5 RS/70 Van
02 WRX Rally Stud
Post
when you painted your calipers, did you remove them???
if you did.. you would have needed to bleed the brake lines... if you did not do this... this could be the source of your problem.
j.
Subie Gal is offline
Old 08-03-2000, 10:07 PM   #7
Andrew
Member#: 1170
2005 STi
Have a Nice Day?
I did not remove them, but i got no where close to the pads or any plastic tubes of any sort. I stayed far away from them...
Andrew is offline
FS: Valvoline 75W90 Tranmission Fluid bwco Vancouver Impreza Club Forum -- VIC 0 05-30-2006 05:57 AM
Help: What color is your tranmission fluid? bwco Vancouver Impreza Club Forum -- VIC 26 08-26-2004 01:49 PM
Which manual tranmission fluid to use? Cjchaps Factory 2.0L Turbo Powertrain 11 08-27-2001 04:49 PM
Is my rear LSD fluid leaking? WRC STi Factory 2.0L Turbo Powertrain 1 06-14-2001 03:42 PM
Message Board Statistics All times are GMT -4. The time now is 04:59 PM.
