Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 05-26-2004, 02:31 PM   #1
mazdman
Member#: 28506
2005 STi
White/Gold
Angry 04 Sti Fuel Filter Costs Over $550.00
I live in PA & got some of the bad gas that
caused my fuel gauge to not read completely full after a fill up. So having the
service manual handy & after talking to the station owner I decided I'd change the level & sub-level sensors & the fuel filter while I'm in there. Why the hell Subaru put the fuel filter in there is beyond me, put here's the best part! Page FU(STi)-60 shows how to remove the fuel filter by twisting the housing open & then replacing the filter and dropping the the FP assy back in the tank. So I call my local dealer to get part #'s & prices & he says they show the filter but don't have a PN for it. So I get a call back about an hour later & he says they called Subaru & that you have to buy the complete fuel pump assy & can't purchase just the filter like the SSM shows. Now *** is Subaru thinking here!? Any feedback would be great.
BTW, the part #'s I got for the sensors
are:
Sub 85111AC012
Level 42081FE020
FP assy $550.00!
mazdman is offline   Reply With Quote
Old 05-26-2004, 02:43 PM   #2
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
can anyone confirm this?
lstepnio is offline   Reply With Quote
Old 05-26-2004, 03:01 PM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I would check the main fuel filter in the engine bay (that one only cost $30). The "filter" that is in the tank is only for very large debris. It is really just a screen and I can't see it getting clogged. If it was clogged though it would be very easy to clean yourself and reuse.
mbiker97 is offline   Reply With Quote
Old 05-26-2004, 03:02 PM   #4
mazdman
Member#: 28506
2005 STi
White/Gold
The one I'm talking about IS the main filter, not the sock that you're talking about.
Old 05-26-2004, 03:18 PM   #5
DougM
Member#: 799
2000 2.5 RS Coupe
Mitsubishi EVO IX
Default Re: 04 Sti Fuel Filter Costs Over $550.00
what is this about? I filled up Sunday and my tank didn't read full either. should i be concerned?
DougM is offline   Reply With Quote
Old 05-26-2004, 03:38 PM   #6
TheMadScientist
Member#: 23717
2005 Big red
Could you remove the in tank filter. Then just use the WRX filter in the engine bay.
TMS
TheMadScientist is offline   Reply With Quote
Old 05-26-2004, 03:44 PM   #7
f4phantomii
Member#: 58504
2004 STi w/o wing
Aspen White / Silver
Where is the fuel filter in the engine bay? Is it even remotely possible to get to without removing a bunch of stuff?
-Michael
f4phantomii is offline   Reply With Quote
Old 05-26-2004, 03:47 PM   #8
mazdman
Member#: 28506
2005 STi
White/Gold
Default Re: Re: 04 Sti Fuel Filter Costs Over $550.00
Ashland Marathon made some bad gas that either contained sulfur in high quantities or white lead. I talked to my local master Subaru tech & they've done 25-30 cars already. Some requiring complete cleaning of the fuel tank, replace all filters, injector, intake & combustion chamber cleaning,etc. This has really pissed me off, because Subaru won't cover it under warranty (understandable) and the station owner just submits a claim to some home office & they decide if they will pay for it. One guy actually had engine damage & the bill was over $3000! My car runs OK (just installed my UTEC & made a couple maps up to about 18 psi), I tried a bottle of injector cleaner & am going to wait a few more tanks of gas before going any further. I'm just worried that some junk might dislodge while I'm under high load, cause me to go lean & blow my motor!
Old 05-26-2004, 03:48 PM   #9
DougM
Member#: 799
2000 2.5 RS Coupe
Mitsubishi EVO IX
wow
that sucks
Old 05-26-2004, 03:52 PM   #10
lstepnio
Member#: 10972
2004 Forester X
The 2.0l WRX has a fuel filter in the engine bay and it's very accessible and inexpensive to replace. The STI does NOT have a fuel filter in the engine bay where you would normally find the fuel filter on the 2.0l WRX. According to the factory anuals the fuel filter on the STi is located in the rear tank assembly.
Old 05-26-2004, 03:55 PM   #11
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Whoops. That sucks.
Old 05-26-2004, 03:57 PM   #12
Dynamispeed
Vendor
Member#: 51291
not the 05 WRX's
they appear to be the same as the STI
Dynamispeed is offline   Reply With Quote
Old 05-26-2004, 04:03 PM   #13
mazdman
Member#: 28506
2005 STi
White/Gold
What I said.
Old 05-26-2004, 04:54 PM   #14
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
well.
post a pic with a list of any #'s on the actual filter...
i'm sure subaru didn't make the filter themselves..
DISCOPOPE is offline   Reply With Quote
Old 05-26-2004, 07:25 PM   #15
Jon [in CT]
Member#: 2992
02 WRX Sedan
mazdman, as far as I can ascertain, your Subaru parts guy is telling the truth. Although the 04 STi service manual describes a procedure for inspecting and replacing the STi fuel filter (now part of the fuel pump assembly) the STi parts database doesn't break out any individually orderable parts within the fuel pump assembly. I can't wait until STi owners start hitting that 30K mileage mark.
Here are two avenues to explore. Ask your Subaru parts guy whether there is a separate fuel filter part number for the 2005 STi. Or, ask him to contact Subaru Tech Line.
Maybe he can order a fuel pump assembly, remove the fuel filter and then return the assembly, telling SOA to bill him for the difference.
Jon [in CT] is offline   Reply With Quote
Old 05-26-2004, 07:33 PM   #16
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Maybe he can order a fuel pump assembly, remove the fuel filter and return the assembly, telling SOA to bill him for the difference.
I just confirmed here in Canada its the same situation as Jon says
FWIW my parts guy says that Subaru always takes a few years to get these sort of things available as up here the fuel filter is now at the 96k (kilometer)service. I know this is of no help but you can always remove the intank filter and use a 02/03WRX engine bay filter setup.
Here's a picture of my Supra pump install. May as well upgrade the fuel pump while your at it.
Wombat North is offline   Reply With Quote
Old 05-27-2004, 01:39 AM   #17
aznatama
Member#: 60316
2004 STi
oooo Supra filter assy can fit?? if that's the case, will this solve the fuel starvation prblem that the STi has under hard right turns?? I see a collector tank....
how much was it? and is there any tech writeups on it??
aznatama is offline   Reply With Quote
Old 05-27-2004, 02:08 AM   #18
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
thats an .....ARG
good thing im too poor to afford one of these beasts
Old 05-27-2004, 02:18 AM   #19
XT6Wagon
Member#: 524
04 STi
Walburo 255 highpressure pump. 99% as effective, 1/2 the cost. 1/2 the aggrivation to put in.
XT6Wagon is offline   Reply With Quote
Old 05-27-2004, 10:42 AM   #20
vapore0n
Member#: 21356
2010 BMW 335i
damn, 300$ for brake pads, 500$ for a fuel filter? I would concider setting up an external fuel filter.
I also notice that the fuel gauge doesnt go up entirely at a full tank. So, my WRX got full F and would take a while to go down, but now the STI doesnt reach the F and drops down quicker. Stupid lead foot
vapore0n is offline   Reply With Quote
Old 05-27-2004, 10:56 AM   #21
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
http://www.scoobymods.com/forums/showthread.php?t=3265
Peaty is offline   Reply With Quote
Old 05-27-2004, 11:06 AM   #22
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Yeah that guy owns an STI, that doesn't exist on his car.
Old 05-27-2004, 11:10 AM   #23
Wombat North
Member#: 21267
STI, EWG 8cm Green
$80 more, Denso quality with no noise and an easy fit. I like first cost last cost. But to each his own.
aznatama
The filter is the STOCK STI one, also the strainer.
Old 05-27-2004, 11:51 AM   #24
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
TypeC is offline   Reply With Quote
Old 05-27-2004, 02:13 PM   #25
aznatama
Member#: 60316
2004 STi
first cost last cost = buy one good thing instead of several cruddy things...
anyways, so we do have a collector tank? then what's with the fuel starvation problems?? o.O...
STi Fuel Filter? aschnell Service & Maintenance 19 08-16-2009 01:39 PM
04 STi Fuel Filter part number PLEASE!!! IIcx Private 'Wanted' Classifieds 3 08-14-2009 04:13 PM
2004 STI Fuel Filter keirnna Service & Maintenance 11 01-25-2007 11:20 PM
Location of STI fuel filter? RHS Service & Maintenance 10 01-25-2007 11:19 PM
STI Fuel Filter Obsidian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-15-2003 02:03 AM
