Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 05-26-2004, 05:53 PM   #1
rally_wannabe
Member#: 15799
'02 WRX/'06 EVO IX
Vshnu-DPS Stg2/CBRD 405HP
Default ABS + Bumps = Dirty Drawers?
Scott Shadle from NHTSA is looking for Test Candidate Cars.
Primarily Interested in Washington DC/Metro area or Columbus Ohio residents.
If you can reliably recreate this problem please call him.
202 366 2583 office
240 475 0589 mobile
They will want to evaluate the car and then suitable candidates will be leased and taken to Columbus Ohio Testing Facility.
I have never been able to reliably repeat this phenomenom and now that I have KDWSes on the car it is even less apparent.
Things are happening people!
rally_wannabe is offline   Reply With Quote
Old 06-11-2004, 01:32 PM   #2
craigmp50
Member#: 33791
2009 WRX
Lightning Red
I can, in Buffalo NY we have the perfect intersection, lots of craters from Semi's waiting at the red light.
But the brakes don't FAIL, it just engages the ABS.
craigmp50 is offline   Reply With Quote
Old 06-16-2004, 04:43 PM   #3
mj02wrx
Member#: 46335
2002 wrx wagon
wr blue pearl
My abs kicks in under braking on our wonderfully "maintained" roads here in reno. Doesnt happen all the time but when it does the butt pucker occurs if there is someone in front of you.
mj02wrx is offline   Reply With Quote
Old 06-18-2004, 06:31 PM   #4
manchild83
Member#: 55554
2008 GTi
Candy White
My ABS kicks in at the worst times too. Kinda un-nerving at high speeds
manchild83 is offline   Reply With Quote
Old 06-21-2004, 04:47 PM   #5
memphisjames
Member#: 41835
2006 Bitchin' Baja-T
Black on Black!
Try to stop going over railroad tracks. It will trip the ABS every time. I nearly rear ended someone this way at a spot where 3 sets of tracks cross the road next to each other.
memphisjames is offline   Reply With Quote
Old 06-25-2004, 02:27 PM   #6
wrxpassinU
Member#: 54754
2010 Legacy 2.5i
Gray
it seems to me there is no problem with the ABS braking. I think that it is normal that if you are under heavy breaking from a substantial speed that the ABS will go off when one of the tires travels across a much more slippery surface(eg. wet manhole covers or railroad tracks.) Just think about it. If you are braking hard on smooth pavement, your abs will trip when one of your tires travels across a surface that has less traction. I think the ABS is doing its job. I bet this "problem" has more to do with driving to fast and having to stop too quickly than a defect in the ABS system.
just my 2 cents...
-andy
wrxpassinU is offline   Reply With Quote
Old 06-25-2004, 04:20 PM   #7
Howl
Member#: 57830
just my 2 cents...
-andy
Many people agree that the Impreza ABS is either too sensitive or just wacky. Other cars in identical circumstances do not have the same problems. Prior to owning my Impreza I had a Mini-van. The ABS only ever came on in panic stopping situations. Before I pulled the fuse for my ABS in my Impreza the ABS would kick in on snow even from 10mph stops, causing me to slid into intersections. You tell me if that is a safe situation.
edit: Note this ABS problem may have been fixed for the 2004 model, although Subaru won't admit there was a problem prior to that.
Howl is offline   Reply With Quote
Old 06-26-2004, 11:22 AM   #8
manchild83
Member#: 55554
2008 GTi
Candy White
No they have not. I am still getting my ABS kicing on on train tracks and bumpy roads. I am considering installing and ABS switch or pulling the fuse.
Old 07-02-2004, 10:28 PM   #9
BryanH
Member#: 993
Originally posted by manchild83
[b]
THEN YOU NEED TO CALL SCOTT SHADLE! HE IS HAVING PROBLEMS FINDING PEOPLE TO REPRODUCE THE PROBLEM!!!!!
The caps are intentional.
I used to be able to reproduce it but I changed the rims tires springs, and shocks and my car seems to behave now.
BryanH is offline   Reply With Quote
Old 07-07-2004, 04:00 AM   #10
wanger68
Member#: 60299
2001 RS
blue
I have this issue too... I'm bout to rip that damn ABS out! I ended up rear ending someone cause of it... mind you it was a love tap, but its still totally way uncool.
and I'm sketched bout giving up my car to someone for any amount of time... specially if its gonna be taken to ohio...
wanger68 is offline   Reply With Quote
Old 07-12-2004, 03:33 PM   #11
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
I can replicate the problem at any time. I am not in the DC or Columbus areas. My suspension is not stock, but I can return it to that state if I am certain someone with some authority is coming to see how bad it is.
Conduit is offline   Reply With Quote
Old 07-30-2004, 03:37 AM   #12
boneriffic
Member#: 37603
I can reproduce this daily. I suppose I'm of not help with aftermarket rims and tires though.
boneriffic is offline   Reply With Quote
Old 07-30-2004, 03:33 PM   #13
BryanH
Member#: 993
They have a set of stock rims and tires for you to use...but if you can get it to do it on aftermarket rims thats just as good...give him a call.
Old 07-30-2004, 03:53 PM   #14
boneriffic
Member#: 37603
...my english is great.
WRX antilocks + bumps = dirty drawers! westy66 Warranty Issues & SOA Problems 1054 01-28-2013 12:01 AM
2002 WRX + ABS + Bumps = Dirty Drawers? rally_wannabe General Community 60 07-24-2004 02:46 PM
2002 WRX + ABS + Bumps = Dirty Drawers? rally_wannabe Mid Atlantic Impreza Club -- MAIC 26 06-08-2004 02:19 PM
2002 WRX + ABS + Bumps = Dirty Drawers? rally_wannabe Brakes, Steering & Suspension 2 05-29-2004 03:52 AM
2002 WRX + ABS + Bumps = Dirty Drawers? rally_wannabe Mid West Subaru Owners Club Forum -- MWSOC 13 05-27-2004 05:11 PM
