Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-17-2000, 08:28 AM   #1
ShaneW
Member#: 226
1999 Impreza 2.5RS
Rally Blue Pearl
Post getting muffler bolts off
Not to sound like a wuss or anything, but what is the best..er..easiest way to get those exhaust bolts off? Last night I went under my car to install the Stromung, but couldn't get those bolts lose with a 12" wrench and bolt greece.
ShaneW
ShaneW is offline
Old 05-17-2000, 08:31 AM   #2
Marius
Member#: 38
Cool
You need a 6'4" frame, 220lbs, feed it good and lubricate it with the finest ales you can find, off go the bolts...
Marius
99 RS blue
Marius is offline
Old 05-17-2000, 09:12 AM   #3
bluesaint
Member#: 876
Post
Impact wrench works
bluesaint is offline
Old 05-18-2000, 12:58 AM   #4
JasonRan
Member#: 163
1999 2.5 RS
Rally Blue
Post
I used about a bottle of Liquid Wrench and let them soak for about 15 minutes. It was still REAL hard to get them off, but it just took a lot of elbow grease. Be careful of that muffler heat shield too...I cut my hand on it. Good luck!
JasonRan is offline
Installing downpipe, can't get OEM downpipe off j-hook fugazni Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-01-2010 05:14 PM
HELP~Cant get last bolt off for downpipe** Kings028 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-08-2010 09:29 PM
Spring install: I can't get the rear 19mm strut bolts off! rex n effect Brakes, Steering & Suspension 33 03-09-2003 10:33 AM
Can't get drain plug bolt off! SUPER RAD Service & Maintenance 23 11-13-2002 08:33 PM
what to do, have 1 spring installed on front, cant get other front bolts off, GregBolby General Forum Archive 8 08-06-2000 12:45 AM
