Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-17-2000, 11:29 AM   #1
Niggz
Member#: 44
Post Suspension Problems... Need Suggestions.
My '99 RS is running on bone stock suspension. This winter I was run off the road by another car and hit a curb (with front passenger side wheel). After the incident I replaced a rim and had the allignment fixed/wheels balanced.
But I am still having some problems. There is a lot of play in my steering wheel, and the car is real shifty at high speeds. Also, I am getting a really rough ride up front. I just assumed it was either ball joints or tie rods or wheel bearings or maybe even a bent strut...
Well, I just took it to the dealer to have 'em try to fix it and they cannot find ANYTHING wrong with the front end. Nothing bent, struts and springs look ok, ball joints and tie rods ok. Now I am not nuts, I know something is wrong. Does anyone have any other suggestions as to what it could be?
Thanks,
Niggz
[This message has been edited by Niggz (edited May 17, 2000).]
Niggz is offline
Old 05-18-2000, 12:16 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
That is by their standards though, which is within "acceptable wear". You should put it up yourself and wiggle the wheels (the one that went over the curb you should pay mor attention to) and see if you hear anything or if there is a lot of play. If so you have to get under and see if you can eyeball what it is. Could be ball joints, tie rod ends, or in worst-case-scenario, your steering rack itself.
8Complex is offline
need stiffer rear suspension- help, need suggestions please! theguy Brakes, Steering & Suspension 17 11-15-2008 12:46 PM
strange suspension problem, need help fat angel Brakes, Steering & Suspension 2 09-10-2006 08:38 PM
suspension problem, need an experts advice. blackie Brakes, Steering & Suspension 10 09-10-2005 12:50 AM
Need suggestions on suspension noise.... e11ys Brakes, Steering & Suspension 0 08-14-2005 11:56 PM
Ok, front suspension problems...need help Drew888 Brakes, Steering & Suspension 5 04-08-2004 11:16 AM
