Old 05-26-2004, 08:38 PM   #1
quig
Member#: 31079
2000 WRX STI open
white
Unhappy I need help with a 2.5 swap!!!!
well DAMN IT !!! I have done just about everything I know and still can't get this thing to start...someone in the know please please help me... I have a 1995 2.2l impreza that I converted from an auto to a 5mt...then I did all the reaserch on the 2.5 swap bought both a 98 2.5L DOHC and a 2000 SOHC so I would be able to choose the best route for my swap... all the reaserch pointed to the 98 2.5 DOHC as the best bet... I have installed the engine doing all the proper things to prepare(thanks Moose & Hawk) ...I can turn the key and hear the fuel pump cycle... I can turn the key farther and have the engine roll over ...I have fuel in the rail ...I have spark in the plug wires... I CAN'T get the fuel injectors to cycle and send fuel to the cylinders thus no start... I have check everything I know and still nothing... what am I missing... everybody else just drop in start.... but not me HELP HELP HELP!!!!! what the hell am I missing?.... can you tell its been a long go... started tracing wires back on last Friday and I am still no farther ahead does anybody have any insite to my problem...
quig is offline   Reply With Quote
Old 05-26-2004, 09:01 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I hope the timing is all aligned right...
Old 05-26-2004, 09:08 PM   #3
quig
Member#: 31079
2000 WRX STI open
white
do you mean on the belt with the crank and cam gears?? if so the yes we checked everything befor the install...if not that then what did I miss ?? I thought even if the timming was off the duty cycle of the injector would still fire... even out of time but still fire... please elaborate Kost ... I trust your advice... I have check each individual injector and was able to fire them so I know the work....
Old 05-26-2004, 09:16 PM   #4
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
dont worry about timing. its probbly somthing retarded. even if timinig is WACK it should somwhat run, crazy kiddo was runnign a EJ20g with EJ22 NA electronics a while back, and it would still kinda run on its own. did you swap over all electronics from your old motor?
h
supermoose is offline   Reply With Quote
Old 05-26-2004, 09:23 PM   #5
quig
Member#: 31079
2000 WRX STI open
white
everything from the existing 2.2..all the sensors were a direct swap...cam, crank, temp injestors TPS ... you name it they all matched up... but I still removed the engine wire harness from the 2.2 just to be safe .... I have fire I have fuel to the injector but the injector does not pulse when the car is rolling over on the starter... the engine will "kick" like it wants to start... pull the plugs and they are dry as a bone... put your hand on any injector and no "click feeling" while the starter is engaged...
Old 05-26-2004, 09:27 PM   #6
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Do you have voltage to the injectors? Are any DTC's stored? Spray it with some ether to see if it will run, that will verify nothing else (timing) is wrong.
yamarocket630 is offline   Reply With Quote
Old 05-26-2004, 09:32 PM   #7
quig
Member#: 31079
2000 WRX STI open
white
i have voltage but no ground signal? at least thats how I see it... if I hook up an outside power source and then ground the injector it fires... but it seem to have power(11.8 volts on my meter) and no other signal from the ECU... does that make sense to anybody?? The next step was to try ether to confirm timming was not off... I thought you guys might be able to help tho first ( befor risking an explosion )
Old 05-26-2004, 09:48 PM   #8
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
A quick way to check timing... compression should be 180-200psi, and you should have 1-2"hg vacuum while cranking. If so, the internals are pretty good. If you're gettin no ground signal to the injectors, the ECU is either pissed about something or missing a signal... you're going to need a scan tool.
Old 05-26-2004, 09:58 PM   #9
quig
Member#: 31079
2000 WRX STI open
white
Rocket... can you give me a hint as to what to look for in the scanner... any start points??what would have the ECU messed up that only the injectors wont fire?? would the cam or crank sensor not functioning be a possibility( not sending back the proper timming signal?)
Old 05-26-2004, 10:14 PM   #10
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
/_______ GM Technical assitance... ex-technician
Loss of cam signal, crank signal, wacked out MAF or MAP, lots of things can cause no injector toggle. Even something as simple as forgot to hook one of the ECU grounds can do it.
If you have access to a scanner and a known good vehicle, data log a known good car cranking, the data log yours... then play "Where's Waldo" to find the differences.
I'm off to sleep on a hang over... if you can figure that one out, you're as drunk as I am.
Old 05-26-2004, 10:19 PM   #11
quig
Member#: 31079
2000 WRX STI open
white
HEY MAN THANKS!!!! thats exactly what I needed to hear... I now have a place to start again will see if I can borrow a Snap ON scantool and see what I can decipher...at least I have hope again... Is there anything else I can do ...
Old 05-26-2004, 11:09 PM   #12
Structure828
Member#: 50488
1999 GC8 ej20g!
LOL welcome to my wonderful world of swap hell.
I went through it for 6 months.
Due to the incredible feedback from certain people on these boards that helped me finish mine, I will be more then happy to help you. I have loads of diagrams on the 2.2l that I got by mistake when doingmy EJ20G 2.0 Turbo Jspec motor.
Just let me know what you need to know and I will see if I can help, or atleast point you in the right direction.
PM me details
Structure828 is offline   Reply With Quote
Old 05-27-2004, 10:45 AM   #13
quig
Member#: 31079
2000 WRX STI open
white
Structure you have mail!!! anybody else care to take a shot at my problem???
Old 05-27-2004, 12:05 PM   #14
Hawk296
Member#: 14555
1995 Impreza L
Baja
Did you reattach the engine ground from the engine harness to the intake manifold? Ide also check other grounds. I was messing aroudn when i was tired, forgot to reattach that ground and it would crank but not start.
Check all electrical conntectors, check all grounds. thats where I would start.
Hawk296 is online now   Reply With Quote
Old 05-27-2004, 02:49 PM   #15
quig
Member#: 31079
2000 WRX STI open
white
my guys are doing just that right now Hawk if anything turns up I will report back tonight...
Old 05-27-2004, 03:27 PM   #16
quig
Member#: 31079
2000 WRX STI open
white
well its running... turns out the MAS **** the bed from the time I took it off and placed the intake on the bench to the time I reinstalled the intake on the new motor A BIG THANKS !!! to all who had a hand in helping... now to try to set up the TEC II
Old 05-27-2004, 03:57 PM   #17
Structure828
Member#: 50488
1999 GC8 ej20g!
PMed you, and i said that might be 1 of the things
Old 05-27-2004, 11:46 PM   #18
Hawk296
Member#: 14555
1995 Impreza L
Baja
Yeah that would definatly do it... Glad you got it figured out!
Need help with parts for 5 speed swap Ioku Subaru Conversions 2 01-26-2009 11:05 PM
need help with 99 2.5 rs bflowrx Normally Aspirated Powertrain 1 10-21-2007 11:27 PM
need help with WRX 2.5l swap, WRX Heads and UTEC jalow72 Engine Management & Tuning 4 10-07-2005 10:23 AM
need help with parrents 2.5-non turbo hybrid gti 2 Normally Aspirated Powertrain 10 03-13-2005 04:21 AM
Friend needs help with 2001 2.5 rs coupe... 2.5rsracer Normally Aspirated Powertrain 3 03-08-2001 05:06 PM
