Old 05-26-2004, 11:28 PM   #1
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Default Vacuum Question
This is a stupid question because I thought you want as much vacuum as possible, but is it possible to have too much vacuum?
I'm asking because I was able to eliminate the possibly that the Vortech RRFPR was causing my eratic and low idle. My idle is perfect when I left let vacuum off of the top of the intake manifold.
Can I just put a oil breather there to catch oil the top of the intake manifold?
Any suggestions or help would be appreciated.
Benny
benjaminetanyahoo is offline   Reply With Quote
Old 05-26-2004, 11:35 PM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Your boost gauge should read 20hg.
If you leave it open, it will read 0. If you were having bad idle before, then I suspect something else is wrong. Check if your MAP sensor plug is all the way in, I know I've seen it when it wiggles loose.
Wedge is offline   Reply With Quote
Old 05-27-2004, 12:48 AM   #3
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Granted I have a hybrid ej22t SOHC motor, maybe it's just the stock ecu doesn't like the compression and the Link Plus will fix it
Old 05-27-2004, 10:04 PM   #4
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Anybody know where the idle screw it to possibly play with because obiviously not enough air is getting in the engine during idle and when I release vacuum it idles fine. Anybody, maybe I should try swapping out IAC vavle first, but that is obiviously alot of dough
Old 05-27-2004, 10:27 PM   #5
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
sounds like the mixture it too rich, so letting in more air leans it out and makes it idle better.
yamarocket630 is offline   Reply With Quote
Old 05-27-2004, 10:41 PM   #6
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
yeah definately, so now I need to know where that pestering idle screw is at
Old 05-28-2004, 05:48 PM   #7
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Blah
Help please with Vacuum question and oil pressure JLW2007RS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-22-2010 12:22 PM
Vacuum Question! 08SubieWRX Newbies & FAQs 16 01-03-2009 09:49 AM
Hydra vacuum question :) EuroSTI Other Engine Management 1 06-18-2005 10:38 AM
Vacuum questions? ImprezedRS Normally Aspirated Powertrain 9 01-23-2003 02:24 AM
Brake Torquing Launches/Vacuuming Question RobPA Transmission (AT/MT) & Driveline 17 05-06-2002 07:06 PM
