Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 08-04-2000, 12:23 AM   #1
Reiflex
Member#: 774
2000 2.5RS
Silverthorn
Exclamation Removing box air-filter for race day? Bad/Good?
Someone had mention to me before that, until I get a K&N filter to remove the whole air filter from the air box only on race day to get some extra power for auto-x.
I'm thinking about doing this, but what other things should I be aware of or do when doing this.
I'm thinking, putting something over the intake (like a fine mesh-like cloth) just to keep any small solid objects from getting in there.?
-Reiflex
www.reiff.freeservers.com ImprezaRacing
Reiflex is offline
Old 08-04-2000, 12:25 AM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
If you're going to put a mesh cloth over the intake, you'd be just as well leaving your air filter in there... they'll both restrict about the same amount of air
JGard is online now
Old 08-04-2000, 12:29 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I've taken mine out for race day before, but it doesn't make much of a difference. For reference, here is <a href="http://8complex.mwic.org/intake" target="_blank">my intake</a>.
And yes, I use actual Subaru filters in there and drive around with it like that all the time. I will take it out come wintertime, though.
8Complex is offline
Old 08-04-2000, 12:37 AM   #4
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Post
Bad idea.
If you take the stock one off you have to replace with a real filter a fine mesh would reduce the air flow down more that a good filter due to the smaller surface area. That is why filters have folded design or large cones to increase surface area. Also the fine dust (lots of dust on paved track)will clog things up and wear out parts.
Unless you plan on doing alot of tear downs.
david2z4 is offline
Old 08-04-2000, 12:40 AM   #5
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
hey 8, do you have and directions as to how you did that? i'd like to do something like that for mine, but i really don't know enough to just do it on a whim... also, what are you going to do in the winter and pooring rain? can you still cover the scoop up and have that even work?
JGard is online now
Old 08-04-2000, 12:49 AM   #6
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Post
8 I was planing to do that with mine tonite. Was lying in bed 4 am thinking about it. Never seen it done before and here it is. Thanks for the pics.
david2z4 is offline
WTB: ARC Air Box with Filter for 02' WRX kenny Private 'Wanted' Classifieds 3 04-27-2004 08:52 PM
Removed 2nd air filter - downhill from there... Stickee Normally Aspirated Powertrain 21 08-10-2003 04:12 PM
How bad is water leaking through air filter for engine? IMPBOY Normally Aspirated Powertrain 7 10-27-2000 06:51 AM
K&N Air filter for stock box on my2000 w/ map sensor? rally123 Technical Forum Archive 15 06-21-2000 04:29 PM
