Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 08-02-2000, 07:58 PM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post ECU Reset Question (But not "How do I?""
I put on my Stromung Dual and Midpipe today and disconnected the battery while I was doing it. Well, It only took me 15 minutes to do so I hooked up the Battery and then only let it idle for around 5 minutes.
I have heard 20 minutes disconnected and 10 minutes idle. Is that set in stone or should I be OK with 15 minutes and 5 minutes?
Eric
MY00 Aspen White
Eric SS is offline
Old 08-02-2000, 10:44 PM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
I would do it stone cold and for at least 30 minutes.
ImprezaRS dot com is offline
Old 08-02-2000, 10:53 PM   #3
XT6Wagon
Member#: 524
04 STi
Post
I don't know about the RS but the 88 would reset after a little over 5 minutes.
Also it might not truely reset, as Ford's ECU in the SHO can store data for more than a year with no power.
But yes 15min should do it if it will reset at all by that method. Can you imagine service techs sittign around for 1/2 an hour with a pissy customer breathing down thier necks about a Check engine light??
XT6Wagon is offline
Old 08-03-2000, 09:23 AM   #4
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Post
I would guess that service techs have a code pulling tool that can also reset the ECU. I know that many of the code tools can reset the specific check lights without much of a problem. I don't think they use the disconnect the battery method at the dealerships
AaronB is offline
Old 08-03-2000, 10:23 AM   #5
Gambit
Member#: 102
Post
Yeah the mechs has this Tricorder type thing with some cables that plugs to your underside steering rack.It does a whole bunch of suff with the car. Pretty nifty. The mech once showed me how to use on of those things. Yup very UnSubaru like.
Gambit is offline
