Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-16-2000, 03:55 PM   #1
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
Wink Best suspension setup??? with 21mm bar + adj shocks
Hey guys.. what would be the best setup for dry hard cornering with a 21mm cusco bar and adjustable GAB dampers...
right now i have them on 6 of 8 in the rear and 4 of 4 in the front (8 and 4 being stiffest)..
right now at high speed cornerin it feels liek the back end tailing out too much..
any ideas?? thanx!
Orbiter is offline
Old 05-16-2000, 04:51 PM   #2
SubePwr
Member#: 140
1999 RS 2.5
Post
You really should consider getting a pair of rear splats first!!!!
Jim
SubePwr is offline
Old 05-16-2000, 05:53 PM   #3
Tim Prudence
Member#: 216
Post
Your rear bar seems like it is too big. What are the spring rates front and rear? Maybe you might try softening the rear shocks. Or, put more tire pressure in the rear and less in the front. Or, get a bigger front bar.
Sheesh, there's a lot of things you can do (and buying rear splats ain't one of them).
Tim Prudence is offline
Old 05-16-2000, 05:59 PM   #4
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Dude...was that why today on the highway you were wagging all over the place?
I would suggest to you what to do...but I'm sure someone with more experience can help you a lot more than me.
Keiho is offline
Old 05-16-2000, 06:31 PM   #5
8Complex
Member#: 922
04 FXT
Red
Post
If the tail is coming out too much you have too much oversteer. You can soften the rear shocks some or learn to drive it that way.
I highly suggest that you just drop the dampening down on your rear shocks, though. It will cause the car to roll more, but you can't get around that without compensating in the front end more.
8Complex is offline
Old 05-17-2000, 02:34 AM   #6
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
Post
ok ic.. i will turn down the shocks in the back a bit more.. see if that helps
ps.. will a tower brace in the back make any difference?
Orbiter is offline
Best suspension setup for an 06-07 STI? GRUMPY514 Brakes, Steering & Suspension 17 03-28-2007 11:04 PM
Best suspension setup for $500-600 MomoWRX Brakes, Steering & Suspension 17 09-24-2005 12:21 PM
Best suspension setup for under $300 MF-DIF Brakes, Steering & Suspension 2 03-20-2005 10:03 AM
gauging interest... kyb agx suspension setup with kg/mm 1.25" drop springs (jdm) legacy2003 Legacy Forum 2 05-17-2004 12:42 AM
Best suspension setup for street & track 02 T-WREX Brakes, Steering & Suspension 16 10-18-2002 10:16 AM
Message Board Statistics All times are GMT -4. The time now is 08:29 PM.
