Old 05-27-2004, 08:07 PM   #1
sjw
Member#: 44905
'04 wrx 5-door
dirty
Default squeaking noise from clutch pedal?
searched to no avail...
anyone else have a clutch pedal that squeaks for a short time when depressed about 3/4? i nearly had to replace a disc in my back after laying down sideways trying to isolate the noise from the pedal area.
any help is appreciated. thanks.
sjw is offline   Reply With Quote
Old 05-27-2004, 09:31 PM   #2
skrib09
Member#: 39077
2004 wrx
i did, but when i got my oil changed i told them and i guess they lubed up the pivot area. no more squeaky squeak!
skrib09 is offline   Reply With Quote
Old 05-27-2004, 09:33 PM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
You can just use some grease on the pivot points where the clutch pedal is. That usually resolves the problem.
Calvin
cnk is offline   Reply With Quote
Old 05-27-2004, 09:53 PM   #4
Rev1
Member#: 51240
08 Lexus IS350
Little WD-40 worked for me.
Rev1 is offline   Reply With Quote
Old 05-28-2004, 08:51 AM   #5
sjw
Member#: 44905
'04 wrx 5-door
dirty
if you wd-40'd it or greased it yourself, can you describe the exact "pivot point" that you greased? i greased multiple pivoting areas and still the darn noise is there.
Old 05-28-2004, 09:10 AM   #6
Rev1
Member#: 51240
08 Lexus IS350
I sprayed the pivoting point, let it soak, then pumped the clutch, and bloated the excess away. It didn't go away immediately, though.
Click noise from Clutch Pedal? krinksta Newbies & FAQs 34 11-22-2011 08:03 PM
Squeak noise from clutch (Not pedal) subiestar Transmission (AT/MT) & Driveline 7 08-13-2007 04:21 PM
Help: Squeaky/Creaky noise from clutch pedal... Robmat Transmission (AT/MT) & Driveline 3 10-15-2003 03:41 PM
"Spring" or "Rattle" noise from clutch pedal bjteel Warranty Issues & SOA Problems 7 05-30-2002 03:17 PM
Strange noise from clutch pedal 555wagon Normally Aspirated Powertrain 7 02-21-2001 12:45 AM
