Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Vancouver Impreza Club
Old 05-28-2004, 12:53 AM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Default ne1 here know how to change spark plugs on wrx?
it's raining, it's dark, and all my patience went out the door at work... help
Benjamin Tang is offline   Reply With Quote
Old 05-28-2004, 01:27 AM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Should be similar to changing the plugs on any Subaru engine.
For the driver's side, you'll need to (re)move the windshield washer fluid resevoir to access the plugs. For the passenger side, you'll need to remove the intake plumbing.
Pop the spark plug wires off of the spark plugs. Put in your standard spark-plug wrench, and take them out using a ratchet.
Should be pretty easy work.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 05-28-2004, 02:08 AM   #3
bwco
Member#: 44137
it sounds easy, but once you try to do it, it pisses you off... trust me, i've been so pissed doing my own .....
one very important thing.... remember to prepare a magnet stick (bendable is better) cause u'll need it to suck the plug out of the hole....
also, prepare to drop a few things into your engine bay....
bwco is offline   Reply With Quote
Old 05-28-2004, 03:19 AM   #4
Benjamin Tang
Member#: 4496
2009 Forester
red
yeah i noticed that. after 20 minutes in the pouring rain and a work light and i called it quits
any idea what docksteader charges for spark plug change? thinking about going there saturday before i pick up my dad from the airport...
Old 05-28-2004, 03:33 AM   #5
Tricky
Tu ne cede malis sed contra audentior ito
Member#: 28960
2002 Stock WRX Wagon
MBP with door dings
Ben; You don't have a garage to work in?
If you need a space, just come by my house.
It's just a car port, but it's dry...
Let me know if you're so inclined. I think I'm about 5 mins from you.
Tricky is offline   Reply With Quote
Old 05-28-2004, 03:47 AM   #6
dugrant153
Member#: 22505
1985 Old
Rusty
the boxer engine bay doesn't look TOO bad to work with.
imagine working with a WRX engine bay, though. that would be tough.
oh wait... your car IS a WRX! hmm...
http://www.scoobymods.com/forums/sho...p?threadid=166
hope ya folks don't mind me cross-posting.
dugrant153 is offline   Reply With Quote
Old 05-28-2004, 08:49 AM   #7
bender
Member#: 1839
IIRC the wrx has a coil on each of the plugs. you've got to remove the connecter on the coil, then remove the bolt(s) holding the coils on. pull the coil straight out, then you can get at the plugs
bender is offline   Reply With Quote
Old 05-28-2004, 02:31 PM   #8
Benjamin Tang
Member#: 4496
2009 Forester
red
bender i don't have your contact number... are u working today? do u have time to help me out with this?
Old 05-28-2004, 02:57 PM   #9
cachan
Member#: 36715
2001 GC8 2.5 RS
Silverthorne
I just did this last night on my car. I stuck the front end of my car in the garage, and let the back hang into my driveway. It took about 45 mins to do it because I'm slow.
It helps to have a 5/8" spark plug socket (the ones with the rubber inside) to pull out the plug. That way you don't need a magnet. (I used the socket plus 2 x 2" socket extensions. This worked better than a 4" extension because it gives it a bit more bend).
I have a PDM intake, so I had lots of room on the passenger side. On the driver's side I unscrewed the washer resevoir and put it on top of the left strut. I didn't even have to unplug the hose (just the electrical).
I put anti-seize on the threads before threading the plugs back in. I also put dielectric grease on the other end of the plug. As a side benefit, the dielectric grease makes it easy to get the boot back on.
Good luck.
Cheers.
cachan is offline   Reply With Quote
Old 05-28-2004, 03:01 PM   #10
Benjamin Tang
Member#: 4496
2009 Forester
red
apparently the ej20t is not as simple as the ej25.... anyway i got in touch with bender and hopefully he can clean up the mess i created
Old 05-28-2004, 09:34 PM   #11
bender
Member#: 1839
ok... which one of you gave ben my work number???
Old 05-29-2004, 01:24 AM   #12
Benjamin Tang
Member#: 4496
2009 Forester
red
Old 05-30-2004, 12:50 AM   #13
Benjamin Tang
Member#: 4496
2009 Forester
red
a public thank-you to bender for helping me out of my little pickle
what i learned in bender's morning shop class...
1. buy lots of snap on tools.
2. listen to jack fm.
3. acme industrial magnets are an essential item
that is all
How to change spark plugs in an 05 Legacy 2.5 Gondi Service & Maintenance 3 12-11-2007 06:48 PM
A shop to change spark plugs on a WRX for less than $200 stees South East Region Forum 14 08-24-2006 11:18 AM
How to change spark plugs DeKaP Service & Maintenance 2 04-27-2006 08:13 PM
Help, how to change spark plugs Hanzo Service & Maintenance 14 01-21-2002 10:57 AM
How to Change spark plugs on a Phase I DOHC? yebokmj Normally Aspirated Powertrain 5 01-21-2001 04:44 PM
