Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 07-31-2000, 07:45 PM   #1
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Question Tire noise and noise
My 99 RS has about 25,000 miles and I recently started to hear a humming type sound (comming from the back)when cruising about 40mph... Im guessing its tire noise. Does anyone know if the stock tires tend to do this with wear?!
(they appear fine with no uneven wear!)
Also... has anyone actually tested (in decibles) the amount of noise an RS can make without a muffler? I wanted to chop off the pipe/muffler (cat-back) and replace it with 2.5" exhaust + "resotube". The guy at the muffler shop says (and I quote) "Do you know how loud thats gonna be!? It will be blatenly illegal".
I question this because 95 decibles is the legal limit and thats pretty dam loud.
Rich L is offline
Old 07-31-2000, 08:20 PM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Not to scare you, but you could also be hearing differential whine or a wheel bearing.
ColinL is offline
Old 07-31-2000, 10:56 PM   #3
Pilot
Member#: 513
Post
Quite possibly a wheel bearing.
Pilot is offline
Old 08-01-2000, 02:02 PM   #4
richeich
Member#: 1353
2001 Impreza 2.5RS
Thumbs up
I recently picked up a 98 Legacy GT with 18,000 miles on it. Soon afterward I noticed a noise in the rearend. I too suspected rear diff or bearings, especially since the Subie's seem to have bearing problems. Anyway, just because I didn't know when it had been done, I rotated the tires. Bingo, noise moved to the front. It was loud enough that it bugged my wife, and I convinced her to let me dump the RE92's even though they still had mileage left in them. I put new tires on and the noise went away. Just for grins, do an alignment when you get put on new tires, just in case that was a factor in the noise.
Good luck-
Rich
(Oh yeah, the tires looked fine also. Go figure.)
[This message has been edited by richeich (edited August 01, 2000).]
richeich is offline
Old 08-01-2000, 04:09 PM   #5
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
I am experiencing the same thing, once I pass 40mph. On another note I found that when I let go of the gas and drifted the noise would go away. And as soon as I pressed the gas again it would begin.
WRXwannbe is offline
Old 08-01-2000, 04:12 PM   #6
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
Old 08-01-2000, 05:18 PM   #7
Brian
Member#: 68
Post
yeah I have been having a similar problem as well. Above 40 I get a harmonic hummm, it begins to quiet down again at about 85. One thing I noticed though is if push in the clutch and coast the noise is still there. I think mine is the tires but I am not sure. I only have 19,000 on my car now.
Brian is offline
Old 08-01-2000, 08:45 PM   #8
Rich L
Member#: 961
Post
I guess Im lucky that I didnt cut off the muffler yet. Im hoping its the tires humming, but with my luck...
what about the muffler(less) issue? Do you think the RS without a muffler (with just a "cherry bomb" like tip) will be an illegal +95 decibels?
Rich L is offline
Old 08-01-2000, 08:51 PM   #9
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
about the muffler, how loud depends on how big your exhaust pipe is. Gary (gg) had 1 7/8" run from the catalyst back (which is a bit smaller than the stock 50mm) and has no muffler, just a resonated dual tip. It's not that loud but very raspy. I'd say it's a bit louder than my car. (2.25" catback, borla turbo muffler, unresonated tip)
ColinL is offline
Old 08-02-2000, 06:38 PM   #10
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
I have a MY00 RS w/ 5k on it, and i have noticed the same noise, its a low tone humming noise on the highway,(windows closed) if I take my foot off the gas the noise goes away untill I put my foot back on the gas. Now I just installed a JC Sports intake, could the intake be making the noise?
I dont know if the noise was there before I put the intake on. I think ill just swap it out and check. Any other suggestions. Ill post the results of the swap out.
thanks
Jay McDade
MY00 BRP RS
munkis is offline
Old 08-03-2000, 04:53 AM   #11
Flea
Member#: 1658
2013 Impreza Sport
Satin White Pearl
Post
I've got the same hum with my tires...
I've got 43,000 miles on my OBS.
It can be pretty annoying. I had the tires rotated and balanced, but they're still pretty noisy. I know I'm due to get some tires soon, so I'll just make sure to get some better tires. I think they're the BF Goodrich stock tires that are on it now...
Flea is offline
Clunking Noise and Knocking Noise from rear. AWD_Drift Brakes, Steering & Suspension 16 02-14-2011 02:56 AM
Rubbing noise and tapping noise coming from engine bay. (OPEN TO READ MORE) Soulofdarkness Newbies & FAQs 8 12-19-2005 01:11 PM
Advice Gurus - Making a noise, and not a commonly diagnosed type noise? I'm stumped. Hotrodguru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 11-12-2005 09:16 PM
99 obs clutch noise and hatch noise only1agam Service & Maintenance 5 06-11-2004 12:00 AM
Rattles, road noise, and other strange noises [email protected] Car Audio, Video & Security 1 11-15-2001 09:01 AM
