Old 05-28-2004, 10:32 AM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Low boost applications
I'm posting because I'm having problems with my boost controller. So a quick question: does the boost controller only add "tension" to the stock wastegate spring so you can make the boost more and not less?
I just can't seem to get my boost down to 6psi. I'm using a simple boost controller made by Vishnu. Is there a way to adjust the stock wastegate by the nut on the arm? Thanks.
Brent
scoobyimprza is offline   Reply With Quote
Old 05-28-2004, 10:38 AM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
the boost controller <FROM WHAT I UNDERSTAND BUT AM 99% SURE ITS HOW IT WORKS> merely vents pressure so that the wastegate only sees a certain pressure, allowing the gate to open or stay closed, but it all comes down to the wastegate spring
if u mess w/ that arm, ull lower the rpm boost comes in at, which will suck
i believe the stock wrx turbos WG is 7psi? maybe 9? what trurbo r u runnin
Old 05-28-2004, 11:02 AM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I think it is 8psi, some where right around there. It's the TD04.
Yeah, I wasn't even gonna touch the arm because I know how easy it is to mess something up like that.
Old 05-28-2004, 11:19 AM   #4
Safir
Member#: 3873
. Paradise is
like Disney with hookers
the wastegate spring sets the minimum boost pressure, and adding a boost controller will only allow you to make more pressure than that.
the stock WRX wastegate opens at 8 psi with no other form of boost control.
I do not know the solution to your problem, sorry.
Safir is offline   Reply With Quote
Old 05-28-2004, 04:18 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
external wastegate, a different actuator, i know there are others
Old 05-28-2004, 06:01 PM   #6
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
As a temporary solution, you can just adjust the wastegate actuator to hold the wastegate slightly open at all times. It will really hurt spool-up, but you will get lower peak boost.
-Charlie
phattyduck is offline   Reply With Quote
Old 05-28-2004, 07:11 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
but for 2 psi diff id keep the thing shut
Old 05-29-2004, 02:09 AM   #8
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Yeah, but that 2 psi totally throws my timing off.
Charlie, do I tighten or loosen that nut?
Brent
Old 05-29-2004, 09:32 AM   #9
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Adjust the arm to make it slightly longer, and preload the spring in the wastegster actuator, but not quite enough to open the valve. You should be able to get it to open at 5-6 by playing with it.
yamarocket630 is offline   Reply With Quote
Old 05-30-2004, 01:06 AM   #10
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I'll see what I can do with the arm.
What about replacing the spring in the wastegate actuator?
Low Compression/High Boost vs High Compression/Low Boost? JoeTX Newbies & FAQs 31 05-18-2006 05:06 PM
Low Boost Low Boost silvarex2004 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-12-2006 09:04 PM
Low boost when low on fuel rich728 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-28-2004 02:26 PM
low boost and low vac. QfactorRS Normally Aspirated with bolt-on Forced Induction Powertrain 7 07-25-2003 02:30 PM
What to do? High Compression, Low Boost or Low Compression, High Boost. FlooredSubaru Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-29-2003 11:55 AM
