Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 05-28-2004, 11:22 AM   #1
applesauce683
Member#: 38322
Default Sparco Seat Question
I'm about to buy a Sparco Evo seat for my 04 WRX. What mounts do I need for it? I don't need height adjustment but I want it to slide back and forth.
applesauce683 is offline   Reply With Quote
Old 05-28-2004, 06:19 PM   #2
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
You just need a slider and a driver side mount. You can get both from worldoneperformance.com or a few other sites.
afpdl is offline   Reply With Quote
Old 05-29-2004, 01:35 PM   #3
silver04rs
Member#: 38825
you will need:
sliders
side plates
base mount
sparco has 2 styles. the new style makes the seat sit very low. so low you cant see over the gauges but these are better. you can adjust the side plates to the heigth you want. with the old style you cant get the seat very low. with the evo seats you need the side plates anyway because the seats dont have holes in the bottom to mount. just the side
travis- the gravel crew
www.gravelcrew.com
silver04rs is offline   Reply With Quote
Old 05-30-2004, 02:44 AM   #4
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Oh sorry I forgot my sparco was a bottom mount. Listen to ^^him you need the side mounts too.
BTW the new style is great for people who are 6'4" or taller. Gave me like 5-6 inches of headroom when my hair was brushing the ceiling before.
Old 06-03-2004, 11:51 PM   #5
aspera
Member#: 7879
I just ordered the new style ones a few days ago. The shop had some sold units that I got to check out. The new style has holes for both side-mount and bottom mount seats. Basically, it is a flat steel plate with tabs welded on the ends. Seats should sit super-low. The only thing that looked iffy was the seatbelt mount. My current subframe (Cobra) has a super-beefy threaded seatbelt mount. The Sparco slider setup looks a lot better, though.
aspera is offline   Reply With Quote
Old 06-04-2004, 03:05 AM   #6
pio!pio!
Member#: 4190
2008 Impreza WRX STi
do they have the new style in evo2? my ass can't fit in an evo
pio!pio! is offline   Reply With Quote
Old 06-04-2004, 03:16 AM   #7
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
The new style is just a mount, it will bolt up to any sparco seat.
Old 06-04-2004, 10:52 AM   #8
Brett555
Member#: 17721
2015 WRX
Just an FYI, I have the new Sparco laser cut bases (and sliders) in stock for the WRX in both driver and passenger side. These were for a customer who has since cancelled. I'm looking for somebody to do an installation review with photos, so if you are interested, email me at sales at soloracer.com. I'd prefer to sell both driver and passenger side.
Brett555 is offline   Reply With Quote
Old 06-04-2004, 03:37 PM   #9
pio!pio!
Member#: 4190
oic..new style base mount..not the side mounts...
so i would need
1) seat
2) new style base mount
3) slider
4) side mount.
so basically i just need the new style bse mount...
Old 06-04-2004, 04:48 PM   #10
pio!pio!
Member#: 4190
so is there a list of what cars have the new low style base mount designed?
the current list on their website does not list the low style base mount
Old 06-04-2004, 08:13 PM   #11
Brett555
Member#: 17721
2015 WRX
Not sure what you mean by low style, but the new laser cut bases are listed on the top of page 1 here under the heading Flat (requires base and slider only)...
http://www.sparcousa.com/seatPriceList.pdf
Old 06-05-2004, 03:59 AM   #12
pio!pio!
Member#: 4190
this is what I meant by new low style..
Old 06-05-2004, 04:06 PM   #13
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
It fits the same seats its just a better designed mount. The old one took some bending and grinding to fit this one bolts right on.
There are not 2 styles this one replaced the old mount.
Old 06-05-2004, 10:32 PM   #14
pio!pio!
Member#: 4190
IC. So if I bought new mounts w/ the same model # I would get the redesigned mount? Is there a list for which mounts are redesigned (Ie I dont have an Impreza)
Old 06-05-2004, 11:01 PM   #15
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
I dont know if they changed the model number with the new mounts. Just that when I ordered mine I ordered the old ones right when the new ones were coming out. And world one told me there would be a delay because new ones are comming out. I have no idea how it is for non impreza mounts though.
Old 04-03-2005, 05:58 AM   #16
ToddStratton
Member#: 8351
2002 WRX Wagon
Ok, I'm bringing this thread back because I'm having problems getting all my Sparco pieces to fit together.
I have:
Evo 2 Seat (859F)
Aluminum side mounts (490W)
sliders with handle (00493)
hardware kit (50001)
WRX "flat" base, drivers side (400SB010L)
Basic problem: the seat is too wide to fit between the side mounts when put together as recommended on Sparco's site http://www.sparco-usa.com/resourceFiles/20.pdf. The seat base has two sets of holes to mount the sliders to. The sliders I have (00493) only fit the holes that are towards the inside of the base, so that the slider handle can connect the two slider levers.
From what I can tell, I need the sliders mounted to the outside holes, which should give enough extra width to fit the seat. The sliders won't fit on these holes., nor would the handle span the distance to the two levers if mounted there.
Is there another piece I need? Part number 500 is an "adaptor, required with most" on the Sparco part list...but not really mentioned anywhere else.
Can someone with a side mount Sparco seat help out here? Thanks for your help.
Todd
ToddStratton is offline   Reply With Quote
Old 04-04-2005, 05:43 PM   #17
ToddStratton
Member#: 8351
2002 WRX Wagon
Bump...before I start drilling holes!
Todd
Old 04-04-2005, 11:48 PM   #18
aspera
Member#: 7879
The first thing that I would do would be to go to Sparco's website and look at the FLAT seat base diagram. See if it looks like the one that you have. Maybe a Sparco employee built the base wrong or drilled the holes in the wrong place.
Then I'd call Sparco and ask about the width of the EVO 2 seats. Are the EVO2's too wide for standard mounting?
Does the FLAT base fit the car correctly?
Old 04-05-2005, 01:16 AM   #19
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
So you are looking at at least $300 in parts if you buy everything from Sparco? Yikes!
Piper Motorsport did custom brackets (with the same slider) for less than that... somethin to think about if you have a competent race shop in your area..
john
Old 04-06-2005, 06:44 AM   #20
ToddStratton
Member#: 8351
2002 WRX Wagon
The diagram on their site (link above) matches exactly to what I have in front of me (the flat base). I have not put the base into the car yet, but it appears to have correct bolt locations and design. The instructions specifically say to use the "inner holes" which are the only ones that work with the sliders anyway.
The Evo2 may be too wide, but based on the specification sheet (and the difference between the two), so would the Evo.
Does anyone have an Evo2 mounted in an Impreza and has a picture of their setup they can share?
Strangely enough, the local shop I got the seat from (they are much cheaper in Europe) couldn't get the "new" flat mounting brackets, so I ordered those from the U.S. I'll take a picture of what I have put together and post it.
Edit: I measured a few things:
Width of Evo2 seat at mounting point (17")
Width of flat seat base "inner" holes - 14.5 inches
Width of outer holes - 16.5 Inches
Span of slider handle - 11 inches
Drilling new holes (one on each side) in the sliders will make this work when attached to the outer holes, except the slider handle will have to be cut or ditched in favor of two levers.
Thanks,
Todd
Old 04-06-2005, 07:48 PM   #21
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
Thanks,
Todd
same exact problem I had when I put in my sparco corsa. The sparco mounts holes didn't accomodate the width of the seat, even at its widest setting. I drilled my old corbeau base to accomodate the holes and it works fine. I have a brand new, laser cut flat seat mount if anyone wants one
petawabit is offline   Reply With Quote
Old 04-09-2005, 09:28 PM   #22
aspera
Member#: 7879
Have you tried swapping the side brackets Left-to-Right and mounting them inside out? That might give you a quarter inch per side (1/2" total).
Old 04-10-2005, 04:19 AM   #23
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
i tried mounting them inside out, but it gave me less room. haven't tried mounting from left to right as I thought it wouldn't make a difference
Sparco Seats, Sparco Harness Bar, 08 STi Seats and Tons of Wrx harness's Millennium Auto Vendor 'General Sale' Forum 11 08-24-2009 12:33 PM
sparco seat question. GDArex003 Interior & Exterior Modification 3 12-13-2008 06:35 PM
Sparco Seat Question... 1SIKWRX4U2NV Interior & Exterior Modification 2 10-07-2005 02:53 PM
sparco seat question. scooter2 North West Impreza Club Forum -- NWIC 3 01-17-2005 02:13 PM
