#1 |
Member#: 1954
Vehicle:1997 Impreza L/WRS WRB |
I really don't know about this but I've seen people state that just because they bought some "high capacity" injectors ( 550cc for their L imprezas, etc) they gained somewhere along the lines of 63.xxx horepower. Is this even close to true? and if so who sells these "super" 550cc injector kits? Whats scoop?
#2 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
Larger injectors give you the *potential* to make more power, but they won't make more power by themselves. If anything, on an utterly unchanged car, they'd probably make less power. When I say "utterly unchanged", I mean that you didn't let the ECU know in any way that you have bigger injectors in the car. That means the ECU gives the same firing signal (or whatever you want to call it) to the larger injectors as it would give to the original small injectors. So, same pulse width, larger flow rate means more fuel into the engine. You'd probably end up running extremely rich.
I think eventually the O2 sensors would see that very rich state and the ECU would compensate. I don't know if the ECU could compensate enough, but you'd end up either back at ground zero, or still running somewhat rich (which will cost you power). Pat Olsen rolled '99 Legacy 2.5GT 5speed sedan |
#3 |
Member#: 481
unless you can get more air into the combustion chamber, why would you need more fuel? ya dont. get bigger injectors with aspiration mods.
| Thread Tools | |
| Display Modes | |
| PERRIN Performance High Capacity Diff Covers **Now with MORE Color** | PERRIN | Drivetrain | 4 | 12-02-2009 12:25 PM |
| Perrin NEW R160 High Capacity and Cooling Diff Cover - $210 Shipped | CO WRX | Drivetrain | 15 | 08-21-2008 02:32 PM |
| Which is better larger capacity injectors or more smaller injectors | tino | Built Motor Discussion | 42 | 10-24-2007 10:40 AM |
| High Capacity Oil pan for EJ25? | Ultimate Racing | Factory 2.5L Turbo Powertrain | 5 | 09-03-2006 12:06 AM |
| Greddy High Capacity Catch Can | noshow907 | Private 'For Sale' Classifieds | 4 | 12-10-2005 05:13 AM |
