Old 05-28-2004, 06:29 PM   #1
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
Resurected and Swapped
Default Loosing Boost Problem
ok, ive had the supercharger on for about 1500 mles now(hasnt been boosting the whole time,had map probs) anyhow, i'm lossing about psi of boost after the car heats up. when its cold i get a solid 10psi, as the car warms up it drops to 5psi, no matter wht i do. i got a couple ideas but was wondering wht y'all thought. - IC
IdenityCrisis is offline   Reply With Quote
Old 05-28-2004, 07:00 PM   #2
Alpha_32
Member#: 35876
2008 Legacy GT SpecB
Grey
um...this is the N/A forum....we dont do boost.
might wanna try posting in one of the forced induction forums...
Alpha_32 is offline   Reply With Quote
Old 05-28-2004, 10:25 PM   #3
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
lol, thought i clicked on it, guess i didnt, my bad. - IC
Old 05-29-2004, 05:33 AM   #4
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
any thoughts? other than i'm dumb for posting in the wrong forum. - IC
Old 05-29-2004, 08:27 AM   #5
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Is there any type of waste gate on the SC or just boost controlled by pulley size? if it's just pulley size, it's normal to lose some boost on a hot engine or in hot weather, ask anyone with a turbo and an MBC. The compressor is just not as efficient hot.
edit... Livonia eh? ever come out the the BW3 meet?
/______ Waterford, MI
yamarocket630 is offline   Reply With Quote
Old 05-29-2004, 10:00 AM   #6
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
peak psi is controlled by pulley size. it has a bypass valve to releave pressure when not under boost. i know i should lose some boost when it gets hot, but 5psi is a heck of alot to lose. and yeah, i've been coming out to the meets for just over a month. my car is silver with the sideskirts painted and a big bubble on the front which car is you? - IC
Loose shifter problem petregeus Transmission (AT/MT) & Driveline 3 04-03-2006 01:39 PM
loosing boost any idea or is it normal wrxin' Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-01-2003 06:50 PM
diagnosed my loose shifter problem, but need further help DoinkMobb Transmission (AT/MT) & Driveline 16 09-02-2002 01:35 AM
Loosing Boost - Loud howling dyswtric27 Normally Aspirated with bolt-on Forced Induction Powertrain 5 04-19-2002 09:56 PM
Why are so many people loosing boost pressure?? keystone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-08-2001 02:35 PM
