Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 05-29-2004, 12:55 PM   #1
harvey oh
Member#: 23516
Default random misfire code #4/cel 0304
help! both tuners and myself have been wrestling with this recurrent problem. mods are: uppipe, 3" turbo back hiflow cat exhaust system, perrin turbo inlet pipe, ecutek reflash, samco i/c hoses, hks grounding kit, deadbolt monster port & polish on stock turbo.
have replaced egt and maf sensors, reflashed and replaced ecu, 1 step colder plugs (both iridium and copper which both sets looked fine upon inspection), also switched coil packs around but still get solid cel lite #0304(#4 misfire)
sorry for long post but really need help on this one before i change to sti injectors and /or fuel rails.
thanks harvey
harvey oh is offline   Reply With Quote
Old 05-29-2004, 02:02 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Do a compression check and see if a new shortblock is needed....
It may very well be that you have a bad #4....
Old 05-29-2004, 07:44 PM   #3
wix
Member#: 29391
Does the check engine light flash when at idle?
wix is offline   Reply With Quote
Old 05-29-2004, 08:23 PM   #4
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
If switching the coil packs didn't help than its probably compression related. I would wager that the compression in #4 is between 70-90.
I speak from experience. At first the misfires were random. Than they became continuos ands always on 4
LiquidForce is offline   Reply With Quote
Random misfire codes when idling soukihei Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-11-2009 08:01 PM
CEL Misfire code D 03 surith Service & Maintenance 2 10-18-2006 07:49 PM
CEL Misfire Codes amye66 Service & Maintenance 5 06-12-2005 12:22 AM
awesome! my CEL was a misfire code!!!! Handsdown Off-Topic 21 10-10-2004 10:32 PM
0304/0301 misfire codes harvey oh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-28-2004 06:12 AM
