Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 04-08-2005, 12:16 AM   #1
crazycraig
Member#: 34934
2004 STI
Default Abs light on after flush
I have a question, I just replaced the brake lines on my Sti and flushed the brake fluid, the brakes feel fine and I believe I got all the air out of the system. The problem is that when I started the car and started moving the car the abs light came on, it wasn't on when I first started the car to test the brake pedal. I have bled many brakes with very little problems (but this is my first abs system), I suction bled the brakes.
I am going to let the car sit till monday, and try to rebleed the system. Do I have to reset the abs computer or something?
Craig
crazycraig is offline   Reply With Quote
Old 04-08-2005, 07:29 PM   #2
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
Did you bleed the brakes with the car running ? The ABS pump may have air in it . You may also want to make sure all of the ABS sensor are tight .
imprezzakc is offline   Reply With Quote
Old 04-08-2005, 08:20 PM   #3
orndog
Member#: 34670
2013 No gears!
Saltine American
Did you put teflon tape on the bleeder screw threads? Ours (at least non-STi) don't seem to seal completely without this addition... not well enough for the suction method anyway.
orndog is offline   Reply With Quote
Old 04-08-2005, 09:03 PM   #4
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
teflon tape on brakes is a really bad idea . It wont hold up to the heat . If you are having leaks from the Banjo bolt the problem is usually the copper washers . You need to have one on both sides of the banjo fitting and they are one use only .
Old 04-08-2005, 10:10 PM   #5
crazycraig
Member#: 34934
2004 STI
I didn't have the car running when I bled the brakes, will try that on monday. I always use some kind of thread sealant on the bleeders, it makes them easier to remove in the future.
Craig
Old 04-09-2005, 12:29 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Craig
You took that the wrong way, he was advising you not to bleed/flush with the car running. If you didn't then you can disregard the comment. You don't need to re-bleed with it running, it won't help.
There is a procedure in the service manual for reading stored ABS codes through flashes of the light, you don't need a scanner for this. Find out what codes are stored and you will have a better idea of how to deal with it.
Help ABS light on after 4pot install kovi Brakes, Steering & Suspension 6 01-16-2008 09:48 AM
ABS Light On After Short Circuit bmw50021 Service & Maintenance 2 09-02-2007 04:31 AM
ABS light on after car got high centered and stuck. Chapel General Community 19 02-05-2005 11:31 PM
ABS light on after alignment pt wrx Brakes, Steering & Suspension 2 07-10-2003 07:11 PM
ABS light on after over-revving engine? dead-eye Brakes, Steering & Suspension 4 01-31-2002 07:45 PM
