Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Vancouver Impreza Club
Old 05-30-2004, 05:37 AM   #1
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Default Clutch Noise
Hey all,
I noticed today driving home from Metrotown that I had a squeaky noise coming from the clutch pedal. When I depressed my clutch pedal all the way to the floor, as I raise it up 0-1inches, a small squeak noise came up. It was only noticeable when leaving off of 1st gear.
Anybody have this problem? I thought it was my wet shoes going against the pedal, but I tried it barefoot and it still had the same problem!
fukamoto is offline   Reply With Quote
Old 05-30-2004, 05:40 AM   #2
dcgear
Member#: 14254
2005 Impreza WRX STi
maybe your foot was wet from all the rain we have been having?
for it to only happen in first gear is quite strange tho..
dcgear is offline   Reply With Quote
Old 05-30-2004, 08:55 AM   #3
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
See this page:
http://www.northursalia.com/m...eak/creak.html
I just did this last week. You can use allmost any kind of grease to smooth out the contact between the piston and the pivot, and it's a fairly easy fix.
Necromancer is offline   Reply With Quote
Old 05-30-2004, 10:45 AM   #4
Benjamin Tang
Member#: 4496
2009 Forester
red
ask dendrobrium. he posted his problem/fix with pics and instructions a few months back here.
Benjamin Tang is offline   Reply With Quote
Old 05-31-2004, 04:48 AM   #5
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Just as I was ready to fix the problem, the problem went away
Old 05-31-2004, 04:50 AM   #6
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Don't worry, it will be back. When the weather gets colder, most likely.
Old 05-31-2004, 02:20 PM   #7
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
Yeah my dealer just greased mine and it went away for like 8 months.. Haven't had it on the 04 yet..
420WRX is offline   Reply With Quote
Old 05-31-2004, 02:29 PM   #8
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Really? I thought this only applied to the push-type hydraulic clutches used on the 2.5-liter NA engines. WRX uses a pull-type clutch, and the old skool stuff is the cable clutch (IMHO the best-feeling of the bunch, but then again I don't have knee problems)...
Old 06-01-2004, 01:58 AM   #9
420WRX
Member#: 27752
Yeah it was making a squishy sound and squeaking a bit and it was unusual so it worried me. The service guy claimed they lubed/greased the assembly and wanted to see if it would come back?
Now I've got an 04 with a wacky factory alarm, a faulty foglight relay, and 1st gear synchros that were pretty bad when I got the car have almost died instantly (~16,000KM on the ODO).
So with all that and the new cruise control recall thing I think I will get the car in for a few days, but if I do it all at once it's not so bad right?
I wonder if a loaner covers a few days? Guess it depends on the dealer, unless loaners are a 'Subaru' deal?
Edit: I forgot about the 04 WRX surge under acceleration issue. I would love to see them try and fix it but I want to know what is going to be fixed before they start modding stuff. I don't want my car to be a guinnea pig for a local subaru mechanic.
Old 10-19-2004, 01:12 AM   #10
fukamoto
Member#: 13339
2014 SWP WRX Wagon
bump.
mine is a violent screech..like the ones when u put ur nail down a chalkboard on EVERY shift...EVERY time i press it down...it engages fine..i have an appointment with specialty on wednesday..anybody have any previous p0roblems? any warranty?
edit: ive lubed it more than id like to admit and its still screeching..i got subaru to do it on the 48k and they "fixed" it but 52k here i am..
Old 10-19-2004, 01:13 AM   #11
Ken
Member#: 34
2005 WRX STi
World Rally Blue
Does it feel weird? Sunny's was like that when I tried his car out. it was like woa... (not woa like who dat hottie!?). Mine squeeks slightly but it's just dry under there.
Ken is offline   Reply With Quote
Old 10-19-2004, 01:45 AM   #12
Dendrobium
Member#: 24234
2003 WRX Wagon 5sp
Mine was not a violent screech -- it was more a benign little "chirp" -- almost like there are "crickets" living down there I get it on occasion every fall/winter or even in summer when there is a sudden night time chill -- I used to grease some pivot/rubber-to-metal contact points -- but now I just leave it be. Most of the time, the boxer rumble/music/radio just drowns it out. If I'm being attentive, I amuse myself with the sound it makes during double-clutches -- "squeak-squeak" "squeak-squeak"..
IIRC -- if you stop and park your car in the garage and listen to it, with your ear right up underneath your dash, it will sound worse because your ear will pick up all kinds of mechanical noises/echoes.
Sounds stupid -- but try wearing different pairs of shoes -- I found the sound exasperated by shoes with soft, pliable soles -- heavily cushioned/stiff based shoes give you a "more direct" clutch depress and tended to lessen the squeak -- YMMV.
I wouldn't worry about it too much, good luck!
-- Dendrobium
Dendrobium is offline   Reply With Quote
Old 10-19-2004, 01:54 AM   #13
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Its not like I'm worried, I'm just fed up. I've been hearing a screech and feeling it EVERY time I depress the clutch. When you stand within 2 feet of my car and I step on the clutch, you can hear the clutch sound from outside the car. And when I depress it, you can feel it rub against something?...and its not as smooth as it was before the screech point.
Old 10-19-2004, 03:38 AM   #14
ghostfoot7
Member#: 61040
dead sexy blue!
Yeah, I had this problem... the dealer lubricated it, but it's back.. I'm checking the fix.
Thanks for the link Necromancer!
ghostfoot7 is offline   Reply With Quote
Old 10-19-2004, 03:39 AM   #15
ghostfoot7
Member#: 61040
dead sexy blue!
Wait.. anyone got a link for WRX's??
Old 10-19-2004, 03:53 AM   #16
Nightrunner
Member#: 69667
JGTC Cusco' STi WR1
Contemporary Hair Design
Mind if i join, i have this same problem too. Squeak a little when the clutch is all the way down. Dealer geased it for me once already but the problem is like "wind-wet", squeaking problem just keep coming again. Is there anyway to fix it PERMANENTLY?
Nightrunner is offline   Reply With Quote
Old 10-19-2004, 02:27 PM   #17
Lantec
Member#: 48685
2010 Prius
what if you use graphite lube???
Lantec is offline   Reply With Quote
Old 10-19-2004, 02:51 PM   #18
[YeS.SiR]
Member#: 56602
2012 SWP STi
I have had this problem on the SiR. I went to the dealer to get it greased at every service after a year or so. Dealer says they can't do anything short of replacing the pivot arm on the clutch, which requires taking out the tranny. It is considered regular wear and tear.
I ended up buying a bottle of rust penetrant (basically WD-40) and I lube the pivot arm every few weeks. When I need to change the alutch, I'll get them to change the arm also.
[YeS.SiR] is offline   Reply With Quote
Old 10-19-2004, 07:14 PM   #19
Nightrunner
Member#: 69667
JGTC Cusco' STi WR1
Yes, WD-40 is a good one! Cheap and DIY
STI Clicking Clutch Noises at 12K? Two different noises MidnightSti05 Transmission (AT/MT) & Driveline 1 08-27-2005 02:57 PM
99 obs clutch noise and hatch noise only1agam Service & Maintenance 5 06-11-2004 01:00 AM
('93-'01) Clutch noise, did a search... Jazz95 Impreza Forum 3 05-12-2001 03:45 PM
Abnormal Clutch noises? jacksonww Normally Aspirated Powertrain 1 04-17-2001 03:53 PM
Clutch noise? Herman General Forum Archive 6 11-14-2000 11:45 AM
